When I try to upload it keeps telling me the file is empty (And file is not empty).
I filtered below by node 102 which is the walli node. Hopefully this can help.
2022-02-12 11:38:31.368 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 11:38:45.226 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update received
2022-02-12 11:38:45.228 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_152_2 to 99 (BigDecimal)
2022-02-12 11:38:45.229 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_20_1 to 0 (BigDecimal)
2022-02-12 11:38:45.230 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_153_2 to 99 (BigDecimal)
2022-02-12 11:38:45.230 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_150_2 to 1 (BigDecimal)
2022-02-12 11:38:45.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_151_2 to 1 (BigDecimal)
2022-02-12 11:38:45.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update set wakeup_node to 17 (BigDecimal)
2022-02-12 11:38:45.232 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Set wakeup node to ‘17’
2022-02-12 11:38:45.232 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration pending added for wakeup_node
2022-02-12 11:38:45.233 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update set wakeup_interval to 30 (BigDecimal)
2022-02-12 11:38:45.233 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Set wakeup interval to ‘30’
2022-02-12 11:38:45.234 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration pending added for wakeup_interval
2022-02-12 11:38:45.234 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_13_1 to 100 (BigDecimal)
2022-02-12 11:38:45.235 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored node_id to 102 (BigDecimal)
2022-02-12 11:38:45.239 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 102: Creating new message for command WAKE_UP_INTERVAL_SET to 30s, node 17
2022-02-12 11:38:45.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2022-02-12 11:38:45.240 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2022-02-12 11:38:45.241 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10055 priority from Config to Immediate
2022-02-12 11:38:45.242 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 11:38:45.242 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10055 to queue - size 13
2022-02-12 11:38:45.243 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 11:38:45.243 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 102: Creating new message for application command WAKE_UP_INTERVAL_GET
2022-02-12 11:38:45.244 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2022-02-12 11:38:45.244 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2022-02-12 11:38:45.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10056 priority from Config to Immediate
2022-02-12 11:38:45.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 11:38:45.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Transaction already in queue - removed original
2022-02-12 11:38:45.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10056 to queue - size 13
2022-02-12 11:43:47.530 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Polling…
2022-02-12 11:43:47.531 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Polling deferred until initialisation complete
2022-02-12 11:43:56.285 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 40 06 31 05 04 22 00 20 CA 00 4B
2022-02-12 11:43:56.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=64, callback=0, payload=00 40 06 31 05 04 22 00 20 CA 00
2022-02-12 11:43:56.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=64, callback=0, payload=00 40 06 31 05 04 22 00 20 CA 00
2022-02-12 11:55:59.811 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Handler disposed. Unregistering listener.
2022-02-12 11:55:59.851 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 102: Serialise aborted as static stages not complete
2022-02-12 11:55:59.852 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:3c8b426f:node102.
2022-02-12 11:55:59.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Controller status changed to ONLINE.
2022-02-12 11:55:59.855 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Controller is ONLINE. Starting device initialisation.
2022-02-12 11:55:59.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties.
2022-02-12 11:55:59.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties. MAN=271
2022-02-12 11:55:59.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties. MAN=271. SET. Was 271
2022-02-12 11:55:59.859 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Properties synchronised
2022-02-12 11:55:59.863 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration synchronised
2022-02-12 11:55:59.963 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2022-02-12 11:55:59.963 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising Thing Node…
2022-02-12 11:55:59.964 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:sensor_temperature for QuantityType
2022-02-12 11:55:59.965 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:sensor_temperature for QuantityType
2022-02-12 11:55:59.965 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:scene_number for DecimalType
2022-02-12 11:55:59.967 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:scene_number for DecimalType
2022-02-12 11:55:59.968 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param13 for DecimalType
2022-02-12 11:55:59.968 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param13 for DecimalType
2022-02-12 11:55:59.969 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param11 for DecimalType
2022-02-12 11:55:59.969 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param11 for DecimalType
2022-02-12 11:55:59.970 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param12 for DecimalType
2022-02-12 11:55:59.970 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param12 for DecimalType
2022-02-12 11:55:59.971 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:battery-level for PercentType
2022-02-12 11:55:59.971 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:battery-level for PercentType
2022-02-12 11:55:59.972 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Polling initialised at 1800 seconds - start in 318600 milliseconds.
2022-02-12 11:55:59.973 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Device initialisation complete.
2022-02-12 11:56:01.364 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 00 61 0E 32 02 21 34 00 00 00 05 00 00 00 00 00 00 CA 00 68
2022-02-12 11:56:16.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-02-12 11:56:16.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 11:56:19.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update received
2022-02-12 11:56:19.901 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_152_2 to 99 (BigDecimal)
2022-02-12 11:56:19.902 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update set config_20_1 to 1 (BigDecimal)
2022-02-12 11:56:19.902 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 102: Creating new message for application command CONFIGURATION_SET
2022-02-12 11:56:19.903 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2022-02-12 11:56:19.904 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2022-02-12 11:56:19.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10183 priority from Config to Immediate
2022-02-12 11:56:19.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 11:56:19.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10183 to queue - size 9
2022-02-12 11:56:19.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 11:56:19.906 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 102: Creating new message for application command CONFIGURATIONCMD_GET
2022-02-12 11:56:19.906 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_CONFIGURATION
2022-02-12 11:56:19.907 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2022-02-12 11:56:19.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10184 priority from Config to Immediate
2022-02-12 11:56:19.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 11:56:19.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10184 to queue - size 10
2022-02-12 11:56:19.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 11:56:19.909 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration pending added for config_20_1
2022-02-12 11:56:19.910 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_153_2 to 99 (BigDecimal)
2022-02-12 11:56:19.910 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_150_2 to 1 (BigDecimal)
2022-02-12 11:56:19.911 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_151_2 to 1 (BigDecimal)
2022-02-12 11:56:19.911 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored wakeup_node to 0 (BigDecimal)
2022-02-12 11:56:19.912 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored wakeup_interval to 0 (BigDecimal)
2022-02-12 11:56:19.912 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_13_1 to 100 (BigDecimal)
2022-02-12 11:56:19.913 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored node_id to 102 (BigDecimal)
2022-02-12 11:56:31.363 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 00 61 0E 32 02 21 34 00 00 00 01 00 00 00 00 00 00 CA 00 6C
2022-02-12 12:01:20.317 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 102: Device discovery completed
2022-02-12 12:01:20.320 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 102: Device discovery resolved to thingType zwave:fibaro_fgwceu-201_00_000
2022-02-12 12:01:20.322 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 46: Device discovery completed
2022-02-12 12:01:20.324 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 46: Device discovery resolved to thingType zwave:fibaro_fgd212_03_005
2022-02-12 12:01:20.326 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 60: Device discovery completed
2022-02-12 12:01:20.328 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 60: Device discovery resolved to thingType zwave:sensative_1101011_00_000
2022-02-12 12:01:20.330 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 61: Device discovery completed
2022-02-12 12:01:20.333 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 61: Device discovery resolved to thingType zwave:aeon_zw100_01_010
2022-02-12 12:01:20.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 62: Device discovery completed
2022-02-12 12:01:20.339 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 62: Device discovery resolved to thingType zwave:fibaro_fgwp102_03_002
2022-02-12 12:01:20.342 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 63: Device discovery completed
2022-02-12 12:01:20.345 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 63: Device discovery resolved to thingType zwave:fibaro_fgwp102_03_002
2022-02-12 12:01:25.045 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:3c8b426f:node102.
2022-02-12 12:01:25.046 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Controller status changed to ONLINE.
2022-02-12 12:01:25.047 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Controller is ONLINE. Starting device initialisation.
2022-02-12 12:01:25.057 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties.
2022-02-12 12:01:25.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties. MAN=271
2022-02-12 12:01:25.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Updating node properties. MAN=271. SET. Was 271
2022-02-12 12:01:25.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Properties synchronised
2022-02-12 12:01:25.065 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration synchronised
2022-02-12 12:01:25.069 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2022-02-12 12:01:25.069 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising Thing Node…
2022-02-12 12:01:25.070 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:sensor_temperature for QuantityType
2022-02-12 12:01:25.070 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:sensor_temperature for QuantityType
2022-02-12 12:01:25.071 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:scene_number for DecimalType
2022-02-12 12:01:25.071 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:scene_number for DecimalType
2022-02-12 12:01:25.072 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param13 for DecimalType
2022-02-12 12:01:25.073 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param13 for DecimalType
2022-02-12 12:01:25.073 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param11 for DecimalType
2022-02-12 12:01:25.074 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param11 for DecimalType
2022-02-12 12:01:25.074 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:config_decimal_param12 for DecimalType
2022-02-12 12:01:25.075 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:config_decimal_param12 for DecimalType
2022-02-12 12:01:25.075 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising cmd channel zwave:device:3c8b426f:node102:battery-level for PercentType
2022-02-12 12:01:25.076 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Initialising state channel zwave:device:3c8b426f:node102:battery-level for PercentType
2022-02-12 12:01:25.077 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Polling initialised at 1800 seconds - start in 1092600 milliseconds.
2022-02-12 12:01:25.077 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Device initialisation complete.
2022-02-12 12:01:33.959 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 10 61 0E 32 02 21 34 00 00 00 04 00 00 00 00 00 00 CA 00 79
2022-02-12 12:01:49.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-02-12 12:01:49.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-02-12 12:01:49.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 12:02:03.095 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update received
2022-02-12 12:02:03.098 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_152_2 to 99 (BigDecimal)
2022-02-12 12:02:03.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_20_1 to 0 (BigDecimal)
2022-02-12 12:02:03.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_153_2 to 99 (BigDecimal)
2022-02-12 12:02:03.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_150_2 to 1 (BigDecimal)
2022-02-12 12:02:03.100 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_151_2 to 1 (BigDecimal)
2022-02-12 12:02:03.100 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update set wakeup_node to 17 (BigDecimal)
2022-02-12 12:02:03.101 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Set wakeup node to ‘17’
2022-02-12 12:02:03.101 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration pending added for wakeup_node
2022-02-12 12:02:03.102 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored wakeup_interval to 0 (BigDecimal)
2022-02-12 12:02:03.102 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored config_13_1 to 100 (BigDecimal)
2022-02-12 12:02:03.103 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Configuration update ignored node_id to 102 (BigDecimal)
2022-02-12 12:02:03.106 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Wakeup interval not specified, using 3600
2022-02-12 12:02:03.107 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 102: Creating new message for command WAKE_UP_INTERVAL_SET to 3600s, node 17
2022-02-12 12:02:03.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2022-02-12 12:02:03.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2022-02-12 12:02:03.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10210 priority from Config to Immediate
2022-02-12 12:02:03.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 12:02:03.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10210 to queue - size 16
2022-02-12 12:02:03.111 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 12:02:03.111 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 102: Creating new message for application command WAKE_UP_INTERVAL_GET
2022-02-12 12:02:03.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2022-02-12 12:02:03.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2022-02-12 12:02:03.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Bump transaction 10211 priority from Config to Immediate
2022-02-12 12:02:03.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Adding to device queue
2022-02-12 12:02:03.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Transaction already in queue - removed original
2022-02-12 12:02:03.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Added 10211 to queue - size 16
2022-02-12 12:02:03.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 12:02:03.573 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 10 14 0A 60 0D 01 01 31 05 04 22 00 06 C1 00 5F
2022-02-12 12:02:03.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=20, callback=16, payload=10 14 0A 60 0D 01 01 31 05 04 22 00 06 C1 00
2-02-12 12:02:05.439 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2022-02-12 12:02:18.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 10215: (Callback 14)
2022-02-12 12:02:18.263 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2022-02-12 12:02:18.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 10215: callback 14
2022-02-12 12:02:18.264 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=14, payload=0E 06 66 00
2022-02-12 12:02:18.265 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2022-02-12 12:02:18.266 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 102: Device discovered
2022-02-12 12:02:18.268 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeDone, new event IncludeDone
2022-02-12 12:02:18.269 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2022-02-12 12:02:18.270 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 10216 to queue - size 1
2022-02-12 12:02:18.270 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2022-02-12 12:02:18.271 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller end exclusion
2022-02-12 12:02:18.271 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWaveController include done
2022-02-12 12:02:18.272 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Got an event from Z-Wave network: ZWaveInclusionEvent
2022-02-12 12:02:18.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 10215: Advanced to DONE
2022-02-12 12:02:18.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 66ms
2022-02-12 12:02:18.273 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 10215: Transaction completed
2022-02-12 12:02:18.273 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:10215 DONE
2022-02-12 12:02:18.274 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-02-12 12:02:18.275 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-02-12 12:02:18.275 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 00 B5
2022-02-12 12:02:18.276 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 00 B5
2022-02-12 12:02:18.276 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2022-02-12 12:02:18.277 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 10216: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2022-02-12 12:02:18.277 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
