Hello, everyone, this is my first topic. And after a lot of searching, I couldn’t find out what is the problem because everything looks fine.
Here is my item:
//Fibaro Switch
Switch ZWaveNode2_Switch1"Outdoor Lights" <lightbulb> [ "Switchable" ]
and I have created the rules from the paper UI I don’t know how to put it here. But I think the rules are fine because the lights always go off when nuticDawn Start and goes ON when civilDusk Start. The Problem is sometimes I wake up in the morning I found the lights still on.
and here is the event log when the problem happened and no errors:
2018-10-19 05:18:00.016 [vent.ChannelTriggeredEvent] - astro:sun:local:nauticDawn#event triggered START
2018-10-19 05:18:00.021 [.event.RuleStatusInfoEvent] - 1ed4c2ef-91df-48b9-bca9-bb316b700dd0 updated: RUNNING
2018-10-19 05:18:00.028 [ome.event.ItemCommandEvent] - Item 'ZWaveNode2_Switch1' received command OFF
2018-10-19 05:18:00.039 [.event.RuleStatusInfoEvent] - 1ed4c2ef-91df-48b9-bca9-bb316b700dd0 updated: IDLE
2018-10-19 05:18:00.045 [vent.ItemStateChangedEvent] - ZWaveNode2_Switch1 changed from ON to OFF
2018-10-19 05:29:26.407 [vent.ItemStateChangedEvent] - ZWaveNode2_ElectricMeterKWh changed from 39.76 to 39.81
And this at the dusk when the lights goes on with no problem:
2018-10-19 17:40:00.017 [vent.ChannelTriggeredEvent] - astro:sun:local:civilDusk#event triggered START
2018-10-19 17:40:00.029 [.event.RuleStatusInfoEvent] - 7d48c7de-070a-46f3-b2e3-61b22822fcfa updated: RUNNING
2018-10-19 17:40:00.038 [ome.event.ItemCommandEvent] - Item 'ZWaveNode2_Switch1' received command ON
2018-10-19 17:40:00.047 [.event.RuleStatusInfoEvent] - 7d48c7de-070a-46f3-b2e3-61b22822fcfa updated: IDLE
2018-10-19 17:40:00.053 [vent.ItemStateChangedEvent] - ZWaveNode2_Switch1 changed from OFF to ON
2018-10-19 17:59:26.397 [vent.ItemStateChangedEvent] - ZWaveNode2_ElectricMeterKWh changed from 40.32 to 40.36
Please help
