Figaro FGS-222 inclusion not working (MANUFACTURER not set)
I do have a Fibaro Double Switch FGS-222 which I cannot integrate into openhab. Im an running Openhab 2.5.5 with latest z-wave binding.
I just resetted the FGS-222 and woulf like to include it. Device is recognized as unknown device.
In the debug logs I can see “MANUFACTURER not set”
Not sure if this is a configuration problem or if the device is currently not known in the Z-Wave binding ?
Here some logs I have seen in the console:
Blockquote
09:38:37.496 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:1722b79517c:node8.
09:38:37.500 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:1722b79517c:node8’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
09:38:37.503 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: MANUFACTURER not set
09:38:37.510 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Controller status changed to ONLINE.
09:38:37.513 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Controller is ONLINE. Starting device initialisation.
09:38:37.519 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:device:1722b79517c:node8’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
09:38:37.660 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Updating node properties.
09:38:37.661 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:1722b79517c:node8’ has been updated.
09:38:37.668 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Updating node properties. MAN=2147483647
09:38:37.668 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:1722b79517c:node8’ has been updated.
09:38:37.673 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Properties synchronised
09:38:37.680 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:1722b79517c:node8’ has been updated.
09:38:37.680 [DEBUG] [ave.internal.protocol.ZWaveController] - Event listener added.
09:38:37.685 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Initialising Thing Node…
09:38:37.689 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Polling initialised at 1800 seconds - start in 829800 milliseconds.
09:38:37.694 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 8: Device initialisation complete.
Blockquote
Probably the device isn’t communicating with the controller since the manufacturer information is not known. This could be because it was not included properly (maybe something went wrong during inclusion) or maybe the device is out of range of the controller.
You could try excluding and including again - that might help.
