Is there a way to add the schedule metadata the a DSL Rule created by a .rule file so that it’ll show up on the Schedule view?
No. Rules DSL doesn’t support adding tags to rules in files and to make a rule show up under Schedule the rule needs to be tagged with “Schedule”. You’d have to write the rule in the UI (you can use Rules DSL in the UI) or change to a rules language that does support adding tags to rules (pretty much all of them).
