2020-06-18 06:55:47.287 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename default.sitemap does not match the name home of the sitemap - please fix this as you might see unexpected behavior otherwise.
2020-06-18 06:55:49.080 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename default.sitemap does not match the name home of the sitemap - please fix this as you might see unexpected behavior otherwise.
getting these every so often
my site map label is
sitemap home label=“Home”
file names to items and sitemap are “default” and in correct folders
i have multiple of the sitemap keep get logging say:
2023-10-06 05:32:40.952 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename michael.sitemap does not match the name home of the sitemap - please fix this as you might see unexpected behavior otherwise.
2023-10-06 05:32:40.954 [WARN ] [sitemap.internal.SitemapProviderImpl] - Filename sarah.sitemap does not match the name home of the sitemap - please fix this as you might see unexpected behavior otherwise.
either i reboot i still get it how to of name Filename but not use name of home.sitemap
Did you name your sitemaps „home“ within the sitemap file ?
If so, you need to change this, as the filename needs to be identical to the name used within the file.
