Platform information:
- Hardware: RPi 4
- OS: Raspberian
- Java Runtime Environment: 11
- openHAB version: 3.1.0
Issue of the topic: I’m trying to fill an image item with a camera picture through the camera URL from a rule.
This is what I try from the camera.rules file:
Camera_last_motionpicture.postUpdate(“http://192.168.2.250/zm/cgi-bin/zms?mode=single&monitor=1”) -
Please post configurations (if applicable): Camera_last_motionpicture item set through GUI as image type.
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
If logs where generated please post these here using code fences:
You need to fill a string variable with the base64 data. See here for some example code to convert to base64 there should be some examples that are closer to your use case.
I had my zoneminder in the overview and just used the web url option.
Here is what it looked like: Openhab 3 some of things you can do with it. - YouTube
