I am running OH 2.5.12. I have an item being updated every minute with a lot of text resulting in multiple lines being written to the log, which I have no use for and which simply fills it up too fast.
Reading through other topics, I have tried to filter them out - but with no success. It seems that the filter settings simply dont do anything? I have tried rebooting, restarting etc. - and waited some hours, but no improvement.
This is the relevant part of my log config including the custom filtering at the bottom of my log config (/srv/openhab2-userdata/etc/org.ops4j.pax.logging.cfg);
# Event log appender
log4j2.appender.event.type = RollingRandomAccessFile
log4j2.appender.event.name = EVENT
log4j2.appender.event.fileName = ${openhab.logdir}/events.log
log4j2.appender.event.filePattern = ${openhab.logdir}/events.log.%i
log4j2.appender.event.immediateFlush = true
log4j2.appender.event.append = true
log4j2.appender.event.layout.type = PatternLayout
log4j2.appender.event.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-26.26c] - %m%n
log4j2.appender.event.policies.type = Policies
log4j2.appender.event.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.event.policies.size.size = 16MB
############ CUSTOM FILTERS START HERE #################
# Filter out AduroH2 event feedback (fills up event log)
log4j2.appender.event.filter.eventjunk.type = RegexFilter
log4j2.appender.event.filter.eventjunk.regex = .*(aduroh2_opdata_Output_str|aduroh2_setboiler_Output_str).*
log4j2.appender.event.filter.eventjunk.onMatch = DENY
log4j2.appender.event.filter.eventjunk.onMisMatch = ACCEPT
################# END OF FILTERS ######################
This is the events I would like to filter out of the event.log (all the lines are just about one state change of one item);
2021-04-10 08:40:00.769 [vent.ItemStateChangedEvent] - aduroh2_opdata_Output_str changed from operating_data/time=10/04-21 08:39:12
operating_data/boiler_temp=19.4
operating_data/smoke_temp=124.3
operating_data/return_temp=999.9
operating_data/dhw_temp=109.1
operating_data/external_temp=0.0
operating_data/t6_temp=0.0
operating_data/t7_temp=0.0
operating_data/distance=999
operating_data/photo_level=100
operating_data/shaft_temp=32.8
operating_data/milli_ampere=20
operating_data/oxygen=20.0
operating_data/flow1=0
operating_data/flow2=0
operating_data/flow3=0
operating_data/flow4=0
operating_data/power_pct=0
operating_data/power_kw=0.0
operating_data/oxygen_ref=0.0
operating_data/boiler_ref=21.0
operating_data/mean_out_temp=0.0
operating_data/dhw_ref=0.0
operating_data/forward_ref=0.0
operating_data/sun2_temp=0.0
operating_data/sun_dhw_temp=0.0
operating_data/sun_surplus_temp=0.0
operating_data/pressure=0.00
operating_data/air_flow=0
operating_data/sun_temp=0.0
operating_data/house_valve_state=1
operating_data/chill_out=0.0
operating_data/sun_pumpspeed=0
operating_data/sun_power_kw=0.0
operating_data/cloud_level=0
operating_data/forward_temp=0.0
operating_data/back_pressure=0
operating_data/t1_temp=0
operating_data/air_quality=0
operating_data/feed_low=1500
operating_data/feed_medium=210
operating_data/feed_high=400
operating_data/content=0
operating_data/state=14
operating_data/substate=0
operating_data/boiler_pump_state=0
operating_data/dhw_valve_state=0
operating_data/house_pump_state=0
operating_data/sun_pump_state=0
operating_data/sun_surplus_state=0
operating_data/ashbox_minutes=0.0
operating_data/ashbox_contact=0.0
operating_data/internet_uptime=99
operating_data/off_on_alarm=0
operating_data/contact2=1
operating_data/NA=1
operating_data/NA=0
operating_data/NA=1
operating_data/corr_medium=0
operating_data/NA=0
operating_data/NA=34
operating_data/compressor_clean=0.0
operating_data/fan_speed=0.0 to operating_data/time=10/04-21 08:40:12
operating_data/smoke_temp=128.0
operating_data/dhw_temp=112.3
operating_data/milli_ampere=25
operating_data/NA=1
operating_data/NA=0
operating_data/NA=1
operating_data/NA=0
Any ideas ?
