Platform information:
Hardware: Raspberry 3b+
OS: openhabian
Java Runtime Environment: N/A
openHAB version: 2.5.5
Issue of the topic: Rule Entry in logfile
Hi!
In my logfile i have an entry of an executed rule which i can´t identify.
Is it possible to match the id with the rule somewhere?
I can´t find anything about this in with google?
2020-06-21 20:01:00.758 [.event.RuleStatusInfoEvent] - 86c7dab9-982f-4ae2-9d24-1f45b416f23f updated: RUNNING
2020-06-21 20:01:00.760 [.event.RuleStatusInfoEvent] - 86c7dab9-982f-4ae2-9d24-1f45b416f23f updated: IDLE
is there anywhere a configfile where i can find this rule to this logentry?
Thank you and greetings,
Alex
5iver
(Scott Rushworth)
June 21, 2020, 6:38pm
2
You can find the name of the rule programmatically using scripted automation, by using the Karaf console, or by searching the Paper UI> Rules page for the UID. This was discussed recently…
There is a feature request from a long time ago requesting this. I half implemented it before the ESH reintegration and build system change, which screwed up several of my development environments, including the one with those changes. The local repos are still there, so it shouldn’t be lost. I expect that some day this will get merged in.
Until then, you can get the name of the rule by searching for the UID in Paper UI> Rules. This could also be done in a script…
rule_name = [rule for rule in…
Oh! that was easy… this was a default entry… i didn´t add this… thank you for your help!
