I think I made it meanwhile thaks to your patience and support.
I verified the “Generic Example” step by step with this thread and found one switch missing as well as some naming problems. After resolving that it stated working. Your question actually was the main thing:
Right now it looks quite good, sensors are coming up and down, presense switch is turing on and off according to presence.
Thanks again
Marcus
Switch Present_Timer { expire="1m,command=OFF" }
//need group if a person owns more than one device
Group:Switch:AND(OFF,ON) gperson1Present <present>
Switch person1_Present <present> // master person1 present switch
Switch person1_Present_Timer { expire="30m,command=OFF" }
Switch person1_iphone <network> (gperson1Present) {channel="network:pingdevice:person1Phone:online"}
.rules
val String filename = "Presence.rules"
rule "start system"
System started
person1_Present.sendCommand(OFF) // assume no one is home
rule "StateMainDoor updated and start main Timer"
Item StateMainDoor received update // when Sensor main door gets updated
Present_Timer.sendCommand(ON) // start main timer
//---------------------person1----------------------
rule "Trying to find person within timer window"
Item person1_iphone changed from OFF to ON or
Item person1_iphone changed from NULL to ON or
Item Present_Timer received command OFF
if(person1_Present.state == OFF) {
if(person1_iphone.state == ON) {
person1_Present.sendCommand(ON) // set present ON for Person 1
logInfo(filename, "person1 is Home!!! ")
} else if(person1_iphone.state == OFF) {
person1_Present_Timer.sendCommand(ON) //start timer for Person 1
logInfo(filename, "Trying to find person1 (Timer 30Min is now ON)")
