Fire a rule on Switch Press
I have this item:
String BOSESOUNDDOCK_VOL "Cassa Bose Volume" <switch>
and this Sitemap:
Switch item=BOSESOUNDDOCK_VOL mappings=[VOLUP="Vol +", VOLDW="Vol -", MUTE="Mute"]
I need to fire a rule, check witch button is pressed and do something.
I tried with this rule:
rule "Cassa Bose Volume Handling"
	Item BOSESOUNDDOCK_VOL received command
	logInfo("CassaBOSE",BOSESOUNDDOCK_VOL.state.toString )
	//BOSESOUNDDOCK_VOL.postUpdate("nd")
I see in the logs, that sometime, is not sent the button i pressed, but the last one, and I have to press 2 time the command to send the one I want. It happen also enabling the postUpdate, that reset the status.
Is it possible to avoid this?
Many Thanks
Marco
i solved using 3 different rules, one for each command of the switch:
Item BOSESOUNDDOCK_VOL received command VOLUP
I don’t know if this is the best way, but it seems to work.
Marco
Why don’t you use
	Item BOSESOUNDDOCK_VOL changed
Hi @opus
my switch has 3 button, and I need to detect wich button is pressed of the switch and execute 3 different action
you could check the exact state of your switch between the ā€œthenā€ and ā€œendā€ like:
 if (BOSESOUNDDOCK_VOL.state==VOLUP) {
  else if (BOSESOUNDDOCK_VOL.state==VOLDW) {
  else if (BOSESOUNDDOCK_VOL.state==MUTE) {
@opus
it is what I did, please read my first post, because I have an issue with this configuration.
Sorry, I missed that and I have no experience in that.
You are receiving a command in your rule, so to find out what the command was, you would instead use
logInfo("CassaBOSE",receivedCommand.toString)
Unless the default autoupdate is suppressed, at some point after the command was sent the state of the item would be updated. But when triggering a rule on received command, use the predefined receivedCommand to see what it was.
Hi @watou
Thanks for help, it works like a charm.
Kindly regards
Marco
