Here is a topic that you may find helpful with dates and times. DateTime Conversion (openHAB 2.x)
Here is a rule example for certain times of the day:
//Rule for using time events
rule "Calculate time of day state"
Time cron "0 * * ? * *"
// System started or
// Time cron "0 30 8 * * ? *" or
// Time cron "0 0 0 * * ? *" or
// Channel 'astro:sun:local:civilDawn#event' triggered START or
// Channel 'astro:sun:local:civilDusk#event' triggered END
val String curr_time = now.toString("HH:mm")
val String night_start = "00:00"
var String morning_start = "06:00"
val String day_start = (Sun_Dawn_Start.state as DateTimeType).format("%1$tH:%1$tM")
val String evening_start = (Sun_Dusk_End.state as DateTimeType).format("%1$tH:%1$tM")
val String midnight_time = "24:00"
var new_val = "UNKNOWN"
if (day_start < morning_start) {
morning_start = day_start
switch true {
case night_start <= curr_time && curr_time < morning_start: new_val = "NIGHT"
case morning_start <= curr_time && curr_time < day_start: new_val = "MORNING"
case day_start <= curr_time && curr_time < evening_start: new_val = "DAY"
case evening_start <= curr_time && curr_time < midnight_time: new_val = "EVENING"
// logInfo("Time_Of_Day", "curr_time=" + curr_time + ", night_start=" + night_start + ", morning_start=" + morning_start
// + ", day_start=" + day_start + ", evening_start=" + evening_start + ", midnight_time=" + midnight_time
// + ", new_val=" + new_val)
if (Time_Of_Day.state.toString != new_val) {
logInfo("Time_Of_Day", "Current time of day is now " + new_val)
Time_Of_Day.sendCommand(new_val)
And this is a rule to control a light using the Astro binding to turn it on and a cron time to turn it off.
rule "Front Porch Lights ON"
Channel 'astro:sun:5ed19d26:civilDusk#event' triggered START
FrontPorch_Light.sendCommand(ON)
rule "Front Porch light OFF"
Time cron "0 30 21 ? * *" //OFF at 9:30 pm everyday
FrontPorch_Light.sendCommand(OFF)
Between the link and both rule examples I hope you found something that helps.
