Issue of the topic: First installation and Zulu is not detected
Hi guys, I’m completely new in OpenHAB and today try to install on one device. First I installed Zulu8, then start follow the installation instruction and stuck on this step. When I run a command sudo apt-get install openhab2 in terminal I receive this message:
[openHAB] WARNING: We were unable to detect Java 8 on your system. This is needed before openHAB can be started.
[openHAB] Please install the current version of Java 8 or check the openHAB documentation for details.
When i try to run:
‘’‘sudo /etc/init.d/openhab2 start’’’
I get this error: [FAIL] no java executable found at /usr/bin/java … failed!
Why the script try to run Java on this path?
Because when you install Java using apt, the default version of Java gets symbolically linked to that path. How did you install Zulu?
Since you say you are not that familiar with Linux, I recommend starting with openHABian. You can use the manual install instructions for openHABian and then use openhabian-config to install and set up everything in the standard way.
Hi and thanks for your answer.
Yes, I installed Zulu manually and I do not linked it to this path. I will try now.
openHABian cant run on this device - its a one cheapest TV Box … I’m not very sure why… maybe I can’t make it correct.
I will try with my Raspberry if I can’t fix this
