David_Jurado
(David Jurado de Priego Inverno)
July 18, 2017, 12:00pm
#1
Hello guys!
I am trying to connect to the KNX bus using OH2 and an IPR / S 2.1 ABB ip router.
My problem is that after configuring the knx.cfg and writing the .items and .sitemap files I get no response in either the log file or the installation.
Here I leave the content of my files for you to help me.
.items file
Dimmer TestDimmer “TestDimmer [%s]” (Lights) {knx=“1/3/20,1/3/21,1/3/22”}
knx.cfg file
ip=224.0.23.12
busaddr=0.0.0
ignorelocalevents=true
type=ROUTER
port=3671
localIp=192.168.0.101
autoReconnectPeriod=10
.sitemap file
Switch item=TestDimmer label=“Luz Salón” mappings=[1=“ON”, 0=“OFF”]
log file
2017-07-18 13:29:47.821 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
(This is only one message I get)
Thank you very much!
Dim
(Angelos)
July 18, 2017, 12:54pm
#2
enable TRACE log level for the 2 bundles that do all the work:
Enter in the openHAB2 console ssh openhab@localhost -p 8101
with password: habopen
log:set TRACE org.openhab.binding.knx
log:set TRACE tuwien.auto.calimero
(switch them back to DEFAULT or INFO level afterwards)
monitor openhab.log for messages
You may have to configure your system with a dummy app using ETS for the filter table on the router to allow the telegrams to pass through.
David_Jurado
July 19, 2017, 10:01am
#3
Problem solved! I have already set up the filter table correctly and everything is ok.
Thank you very much for your help! @Dim
Here’s how to do it:
http://knxtoday.com/2015/01/5286/how-to-solve-it-manually-adding-group-addresses-to-the-filter-table.html
