I’ve tried a few openHABian installs using Etcher to burn the image and I keep getting the same error.
[20:30:31] openhabian@openHABianPi:~$ cat /boot/first-boot.log
2018-03-13_22:53:52_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:53_UTC [openHABian] Storing configuration... OK
2018-03-13_22:53:56_UTC [openHABian] Changing default username and password... OK
2018-09-02_20:27:51_UTC [openHABian] Setting up Ethernet connection... OK
2018-09-02_20:27:51_UTC [openHABian] Ensuring network connectivity... OK
2018-09-02_20:27:52_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2018-09-02_20:28:34_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2018-09-02_20:35:18_UTC [openHABian] Installing git package... OK
2018-09-02_20:36:04_UTC [openHABian] Cloning myself... OK
2018-09-02_20:36:06_UTC [openHABian] Executing 'openhabian-setup.sh unattended'...
2018-09-02_20:36:06_UTC [openHABian] Checking for root privileges... OK
2018-09-02_20:36:06_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2018-09-02_20:36:06_UTC [openHABian] Setting timezone based on IP geolocation... OK (America/New_York)
2018-09-02_16:37:44_EDT [openHABian] Setting locale based on openhabian.conf... OK
2018-09-02_16:38:19_EDT [openHABian] Setting hostname of the base system... OK
2018-09-02_16:38:20_EDT [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2018-09-02_16:38:20_EDT [openHABian] Enabling Audio output... OK
2018-09-02_16:38:20_EDT [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2018-09-02_16:39:32_EDT [openHABian] Installing additional needed packages... OK
2018-09-02_16:39:56_EDT [openHABian] Installing additional bluetooth packages... OK
2018-09-02_16:40:09_EDT [openHABian] Adding slightly tuned bash config files to system... OK
2018-09-02_16:40:09_EDT [openHABian] Adding slightly tuned vim config file to system... OK
2018-09-02_16:40:09_EDT [openHABian] Downloading and setting up FireMotD... OK
2018-09-02_16:40:47_EDT [openHABian] Installing Zulu Embedded OpenJDK... FAILED (keyserver)
2018-09-02_16:40:51_EDT [openHABian] Initial setup exiting with an error!
If I start openhabian-config and install stuff from there and reboot, I get a little farther (though the “installing Zulu” error still shows)…
2018-09-02_20:55:37_EDT [openHABian] Starting the openHABian initial setup.
2018-09-02_20:55:37_EDT [openHABian] Storing configuration... OK
2018-09-02_20:55:37_EDT [openHABian] Changing default username and password... SKIPPED
2018-09-02_20:55:37_EDT [openHABian] Setting up Ethernet connection... OK
2018-09-02_20:55:37_EDT [openHABian] Ensuring network connectivity... OK
2018-09-02_20:55:38_EDT [openHABian] Waiting for dpkg/apt to get ready... OK
2018-09-02_20:56:54_EDT [openHABian] Updating repositories and upgrading installed packages... OK
2018-09-02_20:57:08_EDT [openHABian] Installing git package... OK
2018-09-02_20:57:17_EDT [openHABian] Cloning myself... FAILED
2018-09-02_20:57:17_EDT [openHABian] Initial setup exiting with an error!
Any ideas?
