Hi everybody,
I am quite new in the openhab community. Only a few days since I have discovered openhab. First I want to use openhab to see an 1-wire network of temperature sensors that I read now with a Beaglebone ( white ) over a python script and mqtt . I have installed openhab and mosquitto on a Centos 7 computer
in openhab config
mqtt:mymosquitto.url=tcp://localhost:1883
mqtt:mymosquitto.clientId=openhab
my default.items file looks like:
Group All
Group gGroundFloor (All)
Group GF_Living āLiving Roomā (gGroundFloor)
Number MyFirstSensor āTemperature [%.1f C]ā (GF_Living) {mqtt="<[mymosquitto:home/temperature:state:default]"}
my default.sitemap
sitemap default label=āMain Menuā
Frame label=āMy First Sensorā {
Text item=MyFirstSensor
in addons folder I have
[root@smallnas addons]# ls -al
total 12
drwxr-xr-x. 2 root root 46 Feb 29 17:53 .
drwxr-xr-x. 14 root root 4096 Feb 29 17:52 ā¦
-rw-rār--. 1 root root 7590 Feb 1 11:02 org.openhab.action.mqtt-1.8.1.jar
after starting openhab i have in the messages that is subscriberd to mymosquitt mqtt broker .
I am trying now to test :
[root@smallnas ~]# mosquitto_pub -d -t home/temperature -m 20.12
Client mosqpub/7973-smallnas.p sending CONNECT
Client mosqpub/7973-smallnas.p received CONNACK
Client mosqpub/7973-smallnas.p sending PUBLISH (d0, q0, r0, m1, āhome/temperatureā, ā¦ (5 bytes))
Client mosqpub/7973-smallnas.p sending DISCONNECT
or
[root@smallnas ~]# mosquitto_pub -d -t mymosquitto:home/temperature -m 20.12
Client mosqpub/8318-smallnas.p sending CONNECT
Client mosqpub/8318-smallnas.p received CONNACK
Client mosqpub/8318-smallnas.p sending PUBLISH (d0, q0, r0, m1, āmymosquitto:home/temperatureā, ā¦ (5 bytes))
Client mosqpub/8318-smallnas.p sending DISCONNECT
but any value is indicated in openhab UI
If I subscribe in a topic home/temperature
[root@smallnas addons]# mosquitto_sub -d -t home/temperature
Client mosqsub/8749-smallnas.p sending CONNECT
Client mosqsub/8749-smallnas.p received CONNACK
Client mosqsub/8749-smallnas.p sending SUBSCRIBE (Mid: 1, Topic: home/temperature, QoS: 0)
Client mosqsub/8749-smallnas.p received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/8749-smallnas.p received PUBLISH (d0, q0, r0, m0, āhome/temperatureā, ā¦ (5 bytes))
20.12
Where I am wrong ?
Thank you
