- Platform information:
- Hardware: Intel i7 16GB 2T
- OS: Win10 home 1803
- Java Oracle 1.8.0_181-b13 and Zulu 8.31.0.1
- openHAB version: 2.3.0
- Issue of the topic: -------See Below----
- If logs where generated please post these here using code fences:
Newbie:
Per installation, guide installed Zulu via @ Zulu.org
Created and unzipped Zulu 8 into
C: Program Files (86)\Zulu\zulu8.31.0.1-jdk8.0.181-win_i686 folder
Sub folders here: bin,demo,include,jre,lib, and sample
The install did not create zulu_jdk\bin\ should it have ?
How does it get integrated into Win10 ? it was just unzipped to a folder.
Then to Windows Prerequisites:
Added c:\openHAB2 folder
Created a New System Variable based on Java installation directory:
Variable name: JAVA_HOME
Variable value: C: Program Files (86)\Zulu\zulu8.31.0.1-jdk8.0.181-win_i686
Installation: clicked on download took me to
Installed with Chocolatey;
errors
openhab> Native code library failed to load.
java.lang.UnsatisfiedLinkError: no tinyb in java.library.path
Exception in thread “Thread-87” java.lang.NullPointerException
at org.openhab.binding.mochadx10.internal.MochadX10Binding$ReceiveThread.run(MochadX10Binding.java:199)
Q7 openHAB community says uninstall Bluetooth add-on Bindings; It will not uninstall
Q8 Is there a way to tell if java VM is actually running?
Chocolatey put Folders and Files here:
C:ProgramData\chocolatey\ bin,config,helpers,lib,logs,redirects,tools, ……
Q1 answered… Where is the Start.bat file? Found it in lib-openhab-tools and does openHAB and allows browser to open openHAB2
Q2 Shouldn’t openHAB2 folders and files be in the created c:\openHAB2 folder ?
Q3 My c:\openHAB2 folder is empty ?
Q4 How does windows know what version of Java to use ?
Q5 Do I now have two versions of java Oracle and Zulu.
Q6 Do I figure out how to uninstall and start over ?
Get java right
Install openHAB2 into the right directories
I’m stuck can you help?
strong text
