First time setup of MQTT [solved]
Thanks David.
So from your answer I conclude that also config changes using the Ui are permanent.
Just one hint is missing: How do I start the built-in MQTT server? Is there any place in the config (either file or UI) to do it? The PaperUI jusz says: “you need a MQTT server running” but it does not suggest any starting point how ton do it.
Thanks anyway, I have another starting point for my research :smiley: now
Use the openhabian tool.
sudo openhabian-config
Look through the options and find where you can add the mqtt broker.
EDIT: Its located in Optional components then select Mosquitto
Cool, installed!
Next I went into PaperUI config. First question: What shall I add in the field “location”?
Then, which IP is working? Assumption: 127.0.0.1, because its running locally. I also added my passwd in the extended settings. Result: “your server is offline”. Do I have to reboot?
Now I googled and found some hints how to set up the mqtt.con in services, Its not there. I expected the PaperUI to create one. Wheres my mistake this time?
You can manually configure the broker at etc/openhab2/services/mqtt.cfg
I haven’t moved from mqtt 1.x to the new 2.4 binding so I’m not sure of the options for configuring the broker from PaperUI.
Have you installed the mqtt binding?
I believe yes. At least in the page Configuration chevron_right Bindings chevron_right MQTT Thing Binding in the UI I see
MQTT Thing Binding
Link MQTT topics to things
Author: David Graeff
However I did this before I started mosquitto.
Here’s a tutorial that may help with your setup. It’s for migrating from 1.x to 2.4 but should help either way.
The link is good. However I am stuck at the beginning of it. Although I installed mosquitto using the config tool, I don’t have any mqtt.cfg This seems to be wrong.
Edit: mosquitto IS running:
mosquit+ 1968 0.0 0.4 6356 4016 ? S 15:57 0:00 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
FYI, You can restart OH and watch the logs (front tail logs, found on the webUI) to see if the broker gets started.
No I cannot :frowning: I have no clue how to restart OH2. I can restart the PI, but I would loose most output before I can see in in the gui or SSH. But anyhow, I know that mosquitto is running.
I believe my issue is that most users are coming from some older OH version, thats why they have a mqtt.cfg and I don’t. This seems to be the tested and documented path.
Under Things I see:
Generic MQTT Thing Status: OFFLINE - BRIDGE_OFFLINE
Local MQTT Broker Status: OFFLINE - COMMUNICATION_ERROR MqttException
MQTT Boker Status: OFFLINE - COMMUNICATION_ERROR MqttException
In the Broker settings (both) I added user name, passwd, and port 1883
It is a little bit frustrating…
To start and stop OH from the command line use this:
sudo systemctl stop openhab2
sudo systemctl start openhab2
Maybe try using the IP address of your OH server instead of 127.0.0.1
ahh, this is the output (with 127.0.0.1)
2018-12-22 16:53:22.453 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-12-22 16:53:22.490 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-12-22 16:53:22.500 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2018-12-22 16:53:22.530 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-12-22 16:53:34.676 [WARN ] [.MqttBrokerConnectionServiceInstance] - MqttBroker connection configuration faulty: host : You need to provide a hostname/IP!
2018-12-22 16:53:36.065 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-22 16:53:36.392 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-22 16:53:36.411 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2018-12-22 16:53:36.418 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2018-12-22 16:53:46.141 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-22 16:53:47.581 [hingStatusInfoChangedEvent] - ‘mqtt:topic:b091eb34’ changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2018-12-22 16:53:48.188 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.61:8080
2018-12-22 16:53:48.192 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.61:8443
2018-12-22 16:53:48.646 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-12-22 16:53:48.868 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from UNINITIALIZED to INITIALIZING
2018-12-22 16:53:49.005 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from INITIALIZING to OFFLINE
2018-12-22 16:53:49.098 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘127.0.0.1’ with clientid paho4927382951316 and file store ‘/var/lib/openhab2/mqtt/127.0.0.1’
2018-12-22 16:53:49.141 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from UNINITIALIZED to INITIALIZING
2018-12-22 16:53:49.148 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from INITIALIZING to OFFLINE
2018-12-22 16:53:49.163 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘127.0.0.1’ with clientid paho4927556946079 and file store ‘/var/lib/openhab2/mqtt/127.0.0.1’
2018-12-22 16:53:49.215 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
2018-12-22 16:53:49.223 [hingStatusInfoChangedEvent] - ‘mqtt:topic:b091eb34’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2018-12-22 16:53:49.243 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): MqttException
2018-12-22 16:53:49.247 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
2018-12-22 16:53:49.253 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): MqttException
2018-12-22 16:53:49.255 [hingStatusInfoChangedEvent] - ‘mqtt:topic:b091eb34’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
Something is wrong with the IP. I still believe the UI did not create a mqtt.cfg at the right location. Can I get a plain cfg from somewhere and place it manually (including the password config lines)?
Edit: I see in mosquitto.log
1545494550: New connection from 127.0.0.1 on port 1883.
1545494550: Socket error on client , disconnecting.
Use the server IP address, replace 127.0.0.1 with 192.168.1.61
Do you have a mqtt.cfg at etc/openhab2/services?
Use this command to check:
ls /etc/openhab2/services
Does not help, mosquitto.log
1545494862: New connection from 192.168.1.61 on port 1883.
1545494862: Socket error on client , disconnecting.
1545494872: New connection from 192.168.1.61 on port 1883.
edit: here is the log output
2018-12-22 17:10:42.789 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘192.168.1.61’ with clientid paho5941079571809 and file store ‘/var/lib/openhab2/mqtt/192.168.1.61’
2018-12-22 17:10:42.840 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from UNINITIALIZED to INITIALIZING
2018-12-22 17:10:42.851 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from INITIALIZING to OFFLINE
2018-12-22 17:10:42.861 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘192.168.1.61’ with clientid paho5941254556477 and file store ‘/var/lib/openhab2/mqtt/192.168.1.61’
2018-12-22 17:10:42.876 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
2018-12-22 17:10:42.907 [hingStatusInfoChangedEvent] - ‘mqtt:broker:a01955b2’ changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): MqttException
2018-12-22 17:10:42.924 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Timeout
2018-12-22 17:10:42.928 [hingStatusInfoChangedEvent] - ‘mqtt:broker:e8ebb485’ changed from OFFLINE (COMMUNICATION_ERROR): Timeout to OFFLINE (COMMUNICATION_ERROR): MqttException
Try uninstalling the mqtt binding via PaperUI. Then use the following commands to clean the cache and tmp files.
sudo openhab-cli clean-cache
After OH is back up and running reinstall the mqtt binding.
Much better! MQTT is online now. Thanks!
If anyone is reading the thread:
  • First start mosquitto MQTT broker with sudo openhabian-config Its located in Optional components then select Mosquitto
  • Remember user password (user is openhabian)
  • In the openhab GUI install in addons mqtt
  • Then follow Migrating MQTT1 items to MQTT2.4 items
  • you will need to add your user / password combination. I disabled secure connection (TLS)
  • if anything goes wrong, uninstall on PaperUI and clean the cache:
Summary
  • redo the steps above.
Next step for me: Bring my sonoff into the GUI
Glad you have it working.:+1:
Please mark the topic solved by clicking the square box (lower right corner) on the post that provided the solution and edit the title to start with [Solved].
Which addon do you install!?! “MQTT Binding” or " Embedded MQTT Broker"? I’ve already installed the mqtt broker by config. Does the embedded MQTT broker conflict?
It was so simple and pretty running up to OH1.8. Whith OH2 is started the confusion… every new version the complexity increase. Openhab are getting too difficult to be managed, because there isn’ t an official tutorial fully updated, that lead you step by step. To find information I have to search in the forum, spendig a big amount of time because, for a problem there isn’t only one solution and too many things are given for known. I’m getting crazy to bring my sonoff in OH2.4. I loved OH but now with the 2.4 version, if I have to learn again also ho to make the connection with the MQTT broker, then I’m seriously thinking to pass to Home Assistant. I’m very sorry, because I belived in the project OpenHab, but It becames a mess.
sorry for the outburst, I feel a bit 'frustrated because even if I do everything I find written, and while being connected the Sonoff with the mqtt server installed on raspberry, and using the same items and sitemap of the previous version, I can not view in basic ui the sonoff values
Just install mqtt1 again and everything is back :slight_smile:
And yes OH2 is a different product compared to OH1. It required more steps if you do it by text. The idea is that you just don’t to it by textual configuration anymore. HomeAssistant is not easier in this regard, they have “components” and “entities” which is like our Things and (auto linked) Items.
Hi David,
thanks for your suggestion but what do you mean for mqtt1? I mean that I do not choose the version when I install mqtt by the config tool. As you understand, I’m a beginner.
