conbee II USB Dongle connected to a Rapsberry Pi 3
Phoscon App (Dresden Elektronik) installed on this Raspberry Pi
Virtual Machine in my network running OpenHAB2
OpenHAB2 connected to the conbee offered by phoscon
OSRAM bulbs connected to phoscon
Corresponding things added via phoscon to OpenHAB - setup via Paper UI
channels for brightness and color temperature of bulbs added as items, linking done via items file connecting the hue-channel.
I use this setup for a number of similar OSRAM bulbs. But for one group of bulbs installed in a lamp in one room I experience the problem, that when sending commands to all 4 bulbs only a subset of these bulbs react to the command. On the other when sending a similar command from the PWA (phoscon web app) all 4 bulbs react reliably. I do not really know whether it is of importance, but the bulbs are all members of a PWA group - for similar groups this works without any problems.
I am looking for an advice where to start looking - I am really lost on identifying where to start my debugging. Any hint and any help is much appreciated. If there is any kind of information amiss, please let me know and I will provide it.
thank you very much for your fast reply.
I have one item per bulb. And I do a smarthome:send $item ON - with no effect.
And no rule is interfering. EDIT: But I also used to have a Group:Dimmer:AVG - this did not work, either.
Ok, so you have separate items for every bulb and you defined a group in OpenHAB. I have a similar configuration, which works fine for me.
But if you have defined a group in the Phoscon App, there should also be a LightGroup thing in your Inbox in OpenHAB.
Maybe you can try using this LightGroup, instead of the 4 separate bulbs?
edit:
LightGroups/HueGroups are not available in older versions of OpenHAB. I got them after upgrading to OpenHAB 2.5.4
Thank you very much. I just upgrade the docker container and will take a look at my inbox instantly.
EDIT: just checked and the LightGroups appeared in my inbox. I will check it tomorrow - since as you might have imagined, at this time of day almost everybody at home is asleep and if lighting goes wrong this will most certainly change and lead to annoyance
Please note that the group defined here for the dining room is member of another group for the ground floor. So just for completeness, here is the other group definition:
thank you again for your extensive support.
I have gotten around to add the LightGroups that appeared after the OpenHAB2 Upgrade to my items.
Now it looks like this:
I tested this setup using the OpenHAB2 Android App and all 4 bulbs reacted. Problem seems to be fixed.
Although I still don’t understand why the other setup (building a group of bulbs using OpenHAB2-grouping mechanisms) did not work.
Again: thank you very much. I will mark this thread as fixed.
Could you add your suggestion to upgrade OpenHAB2 to a version >= 2.5.6 (I think) to the post I marked as solution? Then every necessary information to reproduce the solution would be in place.
I did some tests yesterday with another group that contains 6 bulbs and I also saw that sometimes not all 6 did react. Have to change my setup to also use the “Hue Groups” instead of the OpenHAB groups
