The thing I am wondering all the time is, why this did not happen on OH3.1 were it was perfectly fine.
To also give you a background info about the hardware:
I am running the pi4 with the official new PoE+ Hat, connected with Draka UC900 RJ45 Hirose TM31 Cable to a Unifi Pro PoE Switch where the INSTAR IN-9020 is also connected to. The switch has a 10GBit Uplink to a unifi dream machine pro. DNS is again a Pi 4 with Pi-hole connected in the same way. In my guess, the network components are not loaded at all.
Nevertheless, thanks again for your time, i am still very happy.
Thanks for the explanation! If i can support you further, just let me knowā¦
One last thing: Can you drop a note in this thread here, when you publish the fix to the next stable OH Release? I would then switch back to the official version. Thanks
Hi @matt1, no the systemload hadnāt any influence to this phenomenon. I tracked the load a long time on my two different pis. My network is on 1GBit/s and I think I donāt have very much traffic in the network. Connections are routet by a switch (not a hub). I didnāt use the wifi module on any pi.
Happy new year this evening an thank you a lot for all your efforts! Let us know, if you need any support for testing or debugging further builds, if you want to do a deep dive in the fifo buffer implementation. I am very happy with the current solution!
Cheers,
Boris.
jwiseman
(Mr. Wiseman (OH 4.3.5 Stable on Pi4))
26
Where can I get this JAR so it doesnāt have to download it every time I clear my cache?
I just uploaded a newer build which needs testing. This one will keep the ipcamera.mjpeg stream running if the camera reboots or goes offline. When the camera comes back online the stream should go back to updating the picture without needing to refresh the browser.
I also fixed a bug for people that create the streams from rtsp sources.
Sorry I wont be doing that as the next stable is 6 months away. You can follow the progress at the link below yourself, after it shows up as āmergedā, it will then be in the next Milestones and eventually in the Stable after that. I recommend you use Milestone builds if you tinker with openHAB at least once a month. The core is stable in all builds and it is easy to swap in and out the bindings if 1 of them has an issue as you have just seen.
