Hi masters
have changes:
/openhab.cfg
security:option=EXTERNAL
/users.cfg
user=123
try to open external link test.suroot.com:123123/openhab.app?sitemap=homes
in browser:
Forbidden
You don’t have permission to access /openhab.app on this server.
in iphone app
request failed: forbidden (403)
what i do wrong?
in local 192.168.1.23:8080… is ok, request user/password and normal access.
yes it 1st to read&
my settings look identical documentation.
the local network identification is requested when there is no description of the parameter security: netmask = 192.168.1.0 / 24, 192.168.100.0/24.
If a parameter is not requested identification. From both LANs resource opens well and without problems.
if it was just so clear and I would have a question to all.
If you have set security:option=EXTERNAL then there should not be a request for username and password if called from local LAN.
If your ip adress from your openHAB server is 192.168.1.23, then your security:netmask should be 192.168.1.0/24
no any firewall
port 8080 up in system by service openhab, i think this limitation is do service openhab, because other web services is working normal.
