Java Runtime Environment: 11.0.15 (Temurin-11.0.15+10) (running in Docker)
openHAB version: 3.3.0 (running in Docker)
ConBee 2 USB stick
Dear community,
I bought a couple of Aqara temperature and humidity sensors, successfully added them to openHAB and display both temperature and humidity values on a layout page.
This is the current code I use:
I simply copy and pasted this code for the other sensors, only with a different ID (Multisensor1, …, Multisensor6).
Now I have some questions regarding the layout/formatting:
I’d like to display the humidity without decimals (e. g. 16:50 |:droplet:61 % |:battery:95 %), so I tried items['Multisensor6Humidity_Humidity'].state.format("%.0f"). This fails (returning undefined) because items['Multisensor6Humidity_Humidity'].state already contains the suffix %, thereby treating it as a string rather than a number (at least that’s what I assume).
Do I have to apply string functions to solve this, e. g. items['Multisensor6Humidity_Humidity'].state.replace(" %", "").toNumber().format("%.0f") (pseudo code)? Or is there a more elegant solution?
The battery level items['Multisensor6Temperature_BatteryLevel'].state sometimes returns NULL and I like to catch this in the display expression, replacing it with a placeholder (e. g. 16:50 |:droplet:61 % |:battery:-).
How can I do that?
As title (["config"].["title"]) I’d like to use the location of the associated thing rather than hard-coding it into the layout page, e. g.:
You could certainly use a ternary expression, but in this case, I think I’d just cheat a little. Unless it returns the complete string"NULL" your battery state is never going to have NULL in it so just use replace:
No, not trivially. The location of the item is stored in a metadata value. This information is not included in the items dictionary for the widgets. The only way to access an items metadata is if that item is fetched directly from the API using an oh-repeater. You would have to reconfigure the entire widget to run a repeater that just returned the one item and then have it also return the semantic metatadata. 99 times out of 100, it’s easier just to code the location in.
Not sure what additional information you are seeking here. I’m pretty sure that the first example (with the parseInt) doesn’t round the values; it truncates. What additional formatting are you thinking beyond that?
Usually parsing and rounding are compute intensive operations, whereas using a formatting string is much cheaper. That’s why I tend to use them if available and feasible.
