juelicher
(Juelicher)
November 27, 2017, 5:11pm
#1
In the docs there is an example of formatting items in log messages:
logDebug("heating-control.rules", "Bedroom: Temperature: %1$.1f°C, Mode %2$s", Bedroom_Temp.state, Bedroom_Heater_Mode.state)
If I try this, only the format strings are printed in the message, but not the values:
logInfo("SmartSmartMeter.rules", "Water Meter updated rule - Cur: %1$d - Last: %2$d - 15min: %3$.2fl - 1h: %4$.2fl - Day: %5$.2fl - Month: %6$.2fl - Year: %7$.2fl", WaterCurrent, WaterLast, WaterMeter_15min.state, WaterMeter_1h.state, WaterMeter_24h.state, WaterMeter_Month.state, WaterMeter_Year.state)
I double checked my rule, but can not find the error. Is there anything I am missing?
Thanks for your help!
rlkoshak
(Rich Koshak)
November 28, 2017, 11:32pm
#2
You might need to cast the state of your Items to Number.
WaterMeter_15min.state as Number, WaterMeter_1h.state as Number,
I’m assuming WaterCurrent, and WaterLast are variables and not Items. If not you need .state on those as well.
No matter what I try, I don’t manage to print a variable to logging.
I made this simple rule:
rule "Variable logging"
Time cron "0/15 * * * * ?" // every 15 seconds
var Number myNumber = 10.01
logDebug("hvd","My number: %1$.2f", myNumber)
I tried variations like
logDebug("hvd","My number: %1$.2f", myNumber.floatValue)
The logging keeps printing
2018-02-07 12:04:45.145 [DEBUG] [g.eclipse.smarthome.model.script.hvd] - My number: %1$.2f
rlkoshak
(Rich Koshak)
February 7, 2018, 4:27pm
#4
Your formatting looks the same as the examples in the docs:
https://docs.openhab.org/administration/logging.html
I can’t say why it is not working. I don’t really use logs like that so have no direct experience to draw from.
You can try:
logDebug("hvd", String::format("My number: %1$.2f", myNumber))
Works like a charm! I hadn’t thought about passing the whole logtext as one string to the logDebug() call.
Thank you very much, @rlkoshak
In case anyone is stumbling over this thread, one can also use the following:
logDebug("hvd", "My number: {}", myNumber)
The way it’s documented it is definitely not working. I put up an issue with the documentation: https://github.com/openhab/openhab-docs/issues/975
