I’ve done a little PR and I’ve been asked to apply formatting rules.
The problem is that I haven’t been able to find any definition of formatting rules and I use IntelliJ and without a definition file I can’t use the Eclipse formatting plugin.
Any help? Someone that is not using Eclipse?
The style has not yet been recreated for IntelliJ unfortunately.
It seems to be a straight forward process however (if you for install Eclipse for a short moment, at least):
We can then import that style into the repository for everyone to use.
No, I’ve no problem is using eclipse formatting rules.
There is a plugin named Eclipse Formatter that does exactly the same formatting as internally uses eclipse code.
I’ve used it in successfully in several projects, but the problem is that I haven’t found where are the formatting rules that the project uses (the eclipse ones)
About the default importer in my experience is not a good solution, because it’s not 100% perfect and produces some differences.
They are setup by eclipse oomph and embedded in the .setup file as far as I know
It will be nice to have them clearly exported as an xml file that can be imported in IntelliJ or used in a maven plugin
openHAB core was just recently moved over back from Eclipse. And Eclipse never had any intention to support IntelliJ (naturally). That might change only now. That’s why I said, export the style from Eclipse, import it into IntelliJ and provide us with the style file. We would then add it to the repo.
Here you go openHAB_formatter.xml (33.4 KB)
(Or if you would have an openHAB eclipse installation you can export the formatter rules).
Thanks hilbrand.
It worked well, I double checked installing eclipse. Only there are some differences in imports when ussing eclipse formatting plugin.
I think that will be nice to have that file in the repository as it is very convenient for not eclipse users.
Also in a future is desired formatting could be enforced in maven build using a plugin
