Hi there,
I`m struggeling a bit with formatting values:
I created this thing, which basically is ok:
UID: http:url:66fe49bee5
label: Corona Mettmann
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: https://services7.arcgis.com/mOBPykOjAyBO2ZKk/arcgis/rest/services/RKI_Landkreisdaten/FeatureServer/0/query?where=&objectIds=75&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnGeometry=false&returnCentroid=false&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=4326&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=&resultRecordCount=&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=pjson&token=
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
contentType: application/json
timeout: 3000
bufferSize: 2048
channels:
- id: cases7_per_100k
channelTypeUID: http:number
label: Inzident pro 100k
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.cases7_per_100k
- id: cases
label: Fälle
description: null
configuration:
- id: death
label: Tote
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.deaths
- id: update
channelTypeUID: http:string
label: Aktualisiert
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.last_update
- id: cases_per_100k
label: Fälle pro 100.000
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.cases_per_100k
- id: EWZ
label: Anzahl Einwohner
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.EWZ
- id: cases_per_population
label: Fälle auf alle Einwohner
description: null
configuration:
stateTransformation: JSONPATH:$.features[*].attributes.cases_per_population
After putting everything into the model, it shows e.g. 15599:
But I would like to have it shown as 15.599 (incl. thousand separator).
Therefore I put the value
%1$,d
into the ‘Add Metadata - State Description - Pattern’ field of that item:
But then, it shows with an Err:
The same works actually for other items of the same thing:
