Frame label="House"
Text item=FrontDoor label="Front Door [MAP(security_contact.map):%s]" valuecolor=[0="orange",1="green", 4="red", >0="silver"]
Text item=BackDoor label="Back Door [MAP(security_contact.map):%s]" valuecolor=[0="orange",1="green", 4="red", >0="silver"]
Text item=HallPIR label="Hall PIR [MAP(security_pir.map):%s]" valuecolor=[0="orange",1="green", 4="red", >0="silver"]
Text item=LoungePIR label="Lounge PIR [MAP(security_pir.map):%s]" valuecolor=[0="orange",1="green", 4="red", >0="silver"]
The “House” label does not render in the BASIC UI whereas it does in Android App and Classic UI.
The HTML looks like this:
<h5 class="mdl-form__title mdl-cell mdl-cell--12-col">
House
</h5>
Do you see any error messages in the logs and is the sitemap post above everything you have in the file?
The main sitemap label and the file name must match like below.
home.sitmap
sitemap home label="Your-SmartHouse"
Frame label="House"
Text item=FrontDoor label="Front Door [MAP(security_contact.map):%s]" valuecolor=[0="orange", 1="green", 4="red", >0="silver"]
Text item=BackDoor label="Back Door [MAP(security_contact.map):%s]" valuecolor=[0="orange", 1="green", 4="red", >0="silver"]
Text item=HallPIR label="Hall PIR [MAP(security_pir.map):%s]" valuecolor=[0="orange", 1="green", 4="red", >0="silver"]
Text item=LoungePIR label="Lounge PIR [MAP(security_pir.map):%s]" valuecolor=[0="orange", 1="green", 4="red", >0="silver"]
I also noticed and corrected some of the spacing between orange and 1 that was missing. The space between Text and item was also modified. Not sure if this will solve the issue but worth a try.
I found out that if I have some items before my first frame, then I don’t have the labels. If I have a frame (even without a label) to start with then I have the labels.
