my idea is to display in one frame two different web pages changing by time.
Therefore I defined an item:
String frame_url
and a rule:
rule "Webseiten im Habpanel Frame wechseln" when Time cron "0 * * ? * *" //every 1 Minute for testing then //die beiden URLs fuer den Wechsel var String cam = "http://192.168.100.72:9000/?action=stream.html" var String map = "https://goo.gl/maps/HKhpna2wD5U2" var String frame_status = frame_url.state.toString if ((frame_status == "UNDEF") || (frame_status == cam)){ logInfo("urls.rules - frame_url danach", "undef oder cam") frame_url.postUpdate(map) } else { frame_url.postUpdate(cam) } end
So far so good BUT but only the live stream of the webcam is shown. Why the frame widget is not showing normal webpages?
