Awesome!
For the reset yes, this is a known Arduino for ESP8266 issue (esp8266/Arduino#1017).
@Lee_Berry exactly what was my issue with my Arduino under my stairs for light and motions sensors.
I do not use ESP but an Ethernet shieldā¦
My lights work with or without Ethernet (stan aloneā¦) but if thereās and Ethernet and and MQTT connection available I can subscribe and publish command/status/info to my brokerā¦
This ty of sketch example is really hard to find on google! Espescially without Ethernet.connect function because it hang for 60 second and I want not the light not be responding every time Arduino tācheck for Ethernet connectionā¦
" but if thereās and Ethernet and and MQTT connection available I can subscribe and publish command/status/info to my brokerā¦"
are you after a broker ? im using HiveMQ.com and paho to test the MQTT broker and configuration ā¦ all very easy to setup.
Guys, I am about to release the v1.4.0. It has, along with a few fixes:
$uptime
device propertynode.subscribe("1"); node.subscribe("2"); ...
if you have a thousand LED. So now, with a fourth parameter to the HomieNode
constructor, you can subscribe to everything. See the LedStrip
example for a concrete use caseBut before, can you please test if your current sketches work / if the new features work without any regression. If you can, thanks.
Link of the archive: https://github.com/marvinroger/homie-esp8266/archive/7c4f6ba6a3eacf08cac6e3b949d1d7e7c4a8875a.zip
Another question, some of you noticed some frequent MQTT disconnections. I personally donāt, but I heard this is a common problem with knolleary/PubSubClient. I am considering, for the v2.0.0, to switch to imroy/pubsubclient, which seems more stable. Do you have any feedback on this library?
My mqtt (Mosquitto) is on my local RaspberryPi with openhab. And a port is open on my LAN and redirected to my services on RaspberryPi so my outside app (android openHab and OwnTracks) have access.
Easy but long learning curveā¦
For what ever reason my LAN reset or crash I wanted my devices to be standalone. I want my light to be turned on (sensors,switches) without MQTT too!
I donāt want my stuff to be dependent to cloudā¦ If I change something I know it
Has anyone got openhab to work ?
i can use another mqtt client to talk via the MQTT broker and then the device , no problem , light on and off and receiving other properties like $uptime
but trying to get openhab working seem to be painful.
I have cut it down the to basics ā¦
Sorry for BOLD TEXT below , must be a mark up in the code!!
items file >
Switch light {mqtt="<[broker:devices/1198d5e0/light/on:state:ON:true],<[broker:devices/1198d5e0/light/on:state:OFF:false],>[broker:devices/1198d5e0/light/on/set:command:ON:true],>[broker:devices/1198d5e0/light/on/set:command:OFF:false]"}
sitemap>
sitemap home label="Main Menu"
Frame label="MQTT" {
Switch item=light label="Office Lamp"
Config
################################# MQTT Persistence #########################################
# Name of the broker as defined in the section MQTT Transport
mqtt-persistence:broker=broker
################################# MQTT Transport ######################################
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with a id you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mqtt:broker.url=tcp://broker.hivemq.com:1883
overall very simple , but i can not get openhab to talk to the MQTT server
found the problemā¦ missed of /set in the items , working now ā¦ 2 days later omg
but interesting the light icons on change with a browserās refresh F5
Hi everyoneā¦ Iāve just received my Wemos D1 mini boards with relay shield and I was wondering if anyone has done any work getting a nice garage sensor setup?
What Iām trying to achieve is being able to activate the relay via MQTT so that it closes for 1 second and then opens again. In addition there also needs to be an open/close sensor to let me know if the garage door is open or closed at the moment.
I can fumble my way through it but hey, if anyone has already put one together then Iād love to borrow some code that works with homie
@marvinroger: with the release 2.2.0 of arduino for esp8266 released, is there and good thing that is planed to go into your framework ?
Asking in a general idea
Yes! There will be support for mDNS querying. In other words, instead of providing the host and port of both your OTA and MQTT servers, you can now provide the mDNS service name if the servers support mDNS, so that it will be discovered automatically.
This is pretty cool.
For those that uses openHAB, I think (not sure on this part tough) openhab2 has a discovery of some sortā¦ maybe it uses mdns also.
Would be cool to have a openhab binding that would support your frameworkā¦ would make life so easy on the integration of the modules in openhab
You misunderstood, I said mDNS querying, not advertising. There is no need for the ESP8266 to advertise itself on mDNS as this is already done on the MQTT broker. So it would be possible to make an openHAB binding that would scan the MQTT broker in order to discover devices.
oh rightā¦ queryingā¦ as in find the mqtt server with a dns nameā¦ sorry my badā¦ but still, you be fun to have a binding to find the module and add them to openhab in a easy fashion !
ā/homie/config.json doesnāt existā !!!
i have configured via the JSON web app etc , works fine.
MQTT broker working fine
Light on and off ā¦
Great
Go to bed , come back the next night
and
"/homie/config.json doesnāt exist" !!!
i have not worked the time frame , but if there is no power for more than 30 mins , the Config is removed
5 mins seems ok
Any ideas ?
Possibly something related to this?
thanks iāll give a try
installed new homie library and i get the following compile error
error: āclass MDNSResponderā has no member named āqueryServiceā
i can not fined the definition of MDNSResponder , any ideas ?
Hi Homie sounds greeat, just what i was looking for, but a canāt get it to configure. checked all dependances in arduino and it compiles and uploads to board.i am using arduino ver 1.6.8. and have tried it on a WeMos D1 R2 and a ESP12E DEV KIT. and get the same error on both.i openā¦http://marvinroger.github.io/homie-esp8266, and get the āwaiting for deviceā i then switch to homie AP and after a few seconds it gets the device info. i then follow the instructions filling in required fields. (do i need http://192.168.0.22 or just 192.168.0.22 in MQTT broker settings)after completing this it says āSending Configurationā then āThere was an error while sending the configuration. Please retry.ā ihave been trying for 2 evenings now. Hope you can help Many thanks Chris.
P.S. Sorry if i have posted this in wrong place.
