Description
This binding integrates bluMartin FreeAir 100 ventilation systems with openHAB via the FreeAir Connect cloud service. Monitor your indoor air quality and control your ventilation system directly from openHAB.
Features
Monitoring:
Temperature sensors (outdoor, supply, extract, exhaust)
Humidity levels (outdoor and extract air)
Air quality (CO2 levels, air pressure)
Fan speeds and air flow rates
Filter status and remaining lifetime
Heat recovery efficiency
Energy savings calculation
Diagnostics (operating hours, error states, WiFi signal)
Control:
Comfort level adjustment (1-5)
Operation mode selection (Comfort, Sleep, Turbo, Turbo Cool)
Requirements
FreeAir 100 device registered at freeair-connect.de
openHAB 5.0.x or 5.1.x
Java with unlimited cryptography policy enabled (for AES-256 encryption on firmware 2.14+)
Tested Firmware Versions
2.9.0 (AES-128)
2.14.0 (AES-256)
2.22.0 (AES-256)
Installation
Download the JAR for your openHAB version from the GitHub Releases
Copy to your
addonsfolder -
Configure via UI or thing file using your FreeAir Connect serial number and password
Links
GitHub: https://github.com/BernieRenner/org.openhab.binding.freeair
Documentation: README
Downloads: Releases
Releases
- 1.1.0 Minor Update (Added filter status descriptions, new channels)
- 1.0.0 Initial Version
Feedback
This is the first release. Feedback and bug reports are welcome.
