This is now present in distribution addons
This binding is a replacement proposal for the current Freebox binding. It adds UoM usage accross all channels and the management of more Free devices (Delta, Repeater Pop, Pop player…).
If you don’t mind you could also add support for the Italian version of the Freebox Pop (Iliadbox, no “Pop” branding, it’s the only one).
I think all you need to do is use http://myiliadbox.iliad.it in place of http://mafreebox.freebox.fr and add the Italian root certificates.
You should be able to find the certificates under “developer” > “HTTPS access”:
If you want your app to work in Italy, in addition to changing the default domain, you should trust this ECC Root CA
If you can’t find them I can send them (though it’s probably best if you get them yourself for obvious trust and security reasons).
FYI the mafreebox domain with an Iliadbox responds like this:
curl -vv http://mafreebox.freebox.fr/api_version
* Trying 212.27.38.253:80...
* Connected to mafreebox.freebox.fr (212.27.38.253) port 80 (#0)
> GET /api_version HTTP/1.1
> Host: mafreebox.freebox.fr
> User-Agent: curl/7.87.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 404 Not Found
< Server: nginx
< Date: Sun, 05 Feb 2023 17:54:54 GMT
< Content-Type: text/plain
< Content-Length: 51
< Connection: keep-alive
* Connection #0 to host mafreebox.freebox.fr left intact
unknown host, use ip address or myiliadbox.iliad.it
and the myiliadbox domain responds as follows:
"box_model_name": "iliadbox (r1)",
"api_base_url": "/api/",
"https_port": 28072,
"device_name": "Iliadbox",
"https_available": true,
"box_model": "ibxgw8-r1",
"api_domain": "[redacted].ibxos.it",
"uid": "[redacted]",
"api_version": "9.1",
"device_type": "FreeboxServer8,1"
Ok to try that. I would be glad if you could send me the certificate.
Sure
If you want your app to work in Italy, in addition to changing the default domain, you should trust this ECC Root CA:
-----BEGIN CERTIFICATE----- MIICOjCCAcCgAwIBAgIUI0Tu7zsrBJACQIZgLMJobtbdNn4wCgYIKoZIzj0EAwIw TDELMAkGA1UEBhMCSVQxDjAMBgNVBAgMBUl0YWx5MQ4wDAYDVQQKDAVJbGlhZDEd MBsGA1UEAwwUSWxpYWRib3ggRUNDIFJvb3QgQ0EwHhcNMjAxMTI3MDkzODEzWhcN NDAxMTIyMDkzODEzWjBMMQswCQYDVQQGEwJJVDEOMAwGA1UECAwFSXRhbHkxDjAM BgNVBAoMBUlsaWFkMR0wGwYDVQQDDBRJbGlhZGJveCBFQ0MgUm9vdCBDQTB2MBAG ByqGSM49AgEGBSuBBAAiA2IABMryJyb2loHNAioY8IztN5MI3UgbVHVP/vZwcnre ZvJOyDvE4HJgIti5qmfswlnMzpNbwf/MkT+7HAU8jJoTorRm1wtAnQ9cWD3Ebv79 RPwtjjy3Bza3SgdVxmd6fWPUKaNjMGEwHQYDVR0OBBYEFDUij/4lpoJ+kOXRyrcM jf2RPzOqMB8GA1UdIwQYMBaAFDUij/4lpoJ+kOXRyrcMjf2RPzOqMA8GA1UdEwEB /wQFMAMBAf8wDgYDVR0PAQH/BAQDAgGGMAoGCCqGSM49BAMCA2gAMGUCMQC6eUV1 pFh4UpJOTc1JToztN4ttnQR6rIzxMZ6mNCe+nhjkohWp24pr7BpUYSbEizYCMAQ6 LCiBKV2j7QQGy7N1aBmdur17ZepYzR1YV0eI+Kd978aZggsmhjXENQYVTmm/XA== -----END CERTIFICATE-----
and this RSA Root CA:
-----BEGIN CERTIFICATE----- MIIFiTCCA3GgAwIBAgIUTXoJE/kJnSKpxk5FjcmqmGah9zcwDQYJKoZIhvcNAQEL BQAwTDELMAkGA1UEBhMCSVQxDjAMBgNVBAgMBUl0YWx5MQ4wDAYDVQQKDAVJbGlh ZDEdMBsGA1UEAwwUSWxpYWRib3ggUlNBIFJvb3QgQ0EwHhcNMjAxMTI3MDkzODEy WhcNNDAxMTIyMDkzODEyWjBMMQswCQYDVQQGEwJJVDEOMAwGA1UECAwFSXRhbHkx DjAMBgNVBAoMBUlsaWFkMR0wGwYDVQQDDBRJbGlhZGJveCBSU0EgUm9vdCBDQTCC AiIwDQYJKoZIhvcNAQEBBQADggIPADCCAgoCggIBANXKZSyCmix6jt7jUmaCP4XF caF4azeYZuA8A4sWQmQXRWTDj8oNClE5w7zo5qUYzHIBOubKY7hhIU7RXYR5Bdny arNRoo5ZBplgEkv3G00IgXY2/lCywPQ8WorAn0k/uaRce239r6EkGC3fxCA3Asnc q9lNkUoWaf0GktJai0DuW7bNY8cq+vzZpy/36ey0LQ4OoehfiA6vlUTVWakpjecJ ller1RfVlgEH26wnerGge3LYBZv27XiahCft54AQLxRY3H/z8XpKsPnJJrrhEvSo 2p64Bd+g7ZbzCdeakrypjVC/eWn14UzbcBVgh0p4F4990LuGxLVqyh6XcZOSSi01 4fpca5xPDCiohEX7ehMLpdURbhKzPj17IpwTmonfVmxkvV8rca1PqhDPEOouwPtc M55eCgtwgSBeDznFKD7s+az/SZYC16GTgyXTCd2lId/J1unZ4pdzNVMAglTpnGgz eQkHvfcVYdJj49tOtW0OpSPBiNIC6LCVY9wtH5dRMm0k+A8QDP+9HQaOs3LIUMwu WGePw6r+eXUYw/2yO0z3zI/63hOpzZVixW+T7h3SY5B+sTrxR9fRD1oyk/rPV4I3 X5mZnyzSowjcN3+hSkGIZBleMO3CHaYleIf1/9HHhCJCVeeJ4kwEWY18Z0A+ohFh D/dipgwmLCDH1/irDT4pAgMBAAGjYzBhMB0GA1UdDgQWBBTcW1RrTVIizaqkrkTI CSw86qDJkTAfBgNVHSMEGDAWgBTcW1RrTVIizaqkrkTICSw86qDJkTAPBgNVHRMB Af8EBTADAQH/MA4GA1UdDwEB/wQEAwIBhjANBgkqhkiG9w0BAQsFAAOCAgEAOfi6 fCuVLJD+vttO34cdB3i5hofmNrzgLh/spnwdm4y9EvvVqDvLdVLEIbvKf0QEcW0Y dwP1BgmKwwHVv9YydHov8Jr4ANoGGXJnPLPcYDhRnixYEQmlTwSL/CLUcQ2hQWXx Oc0k1jJB7uk6TPdX2YJyW4NpIcwI2sa5Dg/L8PqM0/pMYnMyG1hBwUc2M2qg3qTJ zeiYT9zBHxS/JXA40yH4g9NzcFisVuYrfmINb11GmeqClm2OWehSdgdv9tEph3NW ntJTENRrDvuj/pGZsnbofzgHNN6/nanymmrEPxG+xUGLIAW7zFndTKityhJ9FRqF ultoZR2D19hh+n1277TSCPRJzUpq9rrfiqukjua3UjBzEvevnmSbLs1bXcNAxFYN oZZ2euHoBv+E3BHjGik4RUkEJYtf5Xh+iffk4zTMfKBERn40fB7yF1xzxyoziltL VxfueF9V6N7qjo5Ia7kiShXXsB+QdQdweuxWm1pPYmMbfTxNEqFUs3GhwEjzLaJc cJOedwCT4ntbyCcTQaRlDL8QFjdE4gNm2ZaoG+gqGTLPS55H+ZvLsgUCiR5YY44N G2Gkv4w/V/eB3eAvd5lgm6oOe8ehdr5JdpD6wnW2GOHs4SBdBo6yR+4RgEimNmgF Yu11tlZsB2Iw/TT1EyPVb5z6tK4wUgWLNFAvjXU= -----END CERTIFICATE-----
I have just pushed an update on the PR integrating Iliadbox certificate.
Sorry for not getting back to you sooner. I installed the new official add-on for openHAB 4.1 and I confirm it works! I just had to change the URL to myiliadbox.iliad.it
One thing I’d suggest is to state that you need to accept the pairing request on the physical device screen. It took me 10 minutes to figure it out
