I just did a fresh instal of the 2.5.x branch following the IDE setup guide. Installation was fine, but when I try to import bindings (File:Import:Existing Maven Project, go to bundle folder and import) the build ends up with an error check mark on pom.xml of every imported binding (also doesn’t work with just 1):
Overing over the x brings a message
Plugin execution not covered by lifecycle configuration: com.diffplug.spotless:spotless-maven-plugin:1.24.3:check (execution: codestyle_check, phase: initialize)
Selecting “Jump to parent pom” brings me to
Selecting solution “Mark check as ignored in pom.xml” inserts the following into pom.xml
Selecting solution “Mark check as ignored in Eclipse preferences” seems to fix it, but…not sure if this is the solution.
