- Platform information:
- Hardware: RaspberryPi 3B 1.2, SSD Kingston v300 60GB with USB/Sata Adaptor
- OS: Openhabian
Good day.
I have an openhabian installed for a while. At first it was on the SD card. Then by Configuration Tool and move to SSD. Yesterday after the automatic update in the Configuration Tool, RaspberryPi did not want to boot up. After a few attempts I found that it will install everything again. Unfortunately, I still do not want to boot up.
At the beginning I used Etcher to flash SD card and SSD. RaspberryPi does not even show up on the list of devices in the LAN network. I tried different configurations. Same SD card, SSD drive itself, both at once. You do not want to load anything or even connect to the network.
Can someone advise me what could have happened that RaspberryPi died after the upgrade?
Edit:
After several unsuccessful attempts, I managed to launch RPi only from the SSD. The installation is not coming:
Every 2.0s: cat /boot/first-boot.log openHABianPi: Sat May 25 09:27:26 2019
2018-03-13_22:53:36_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:36_UTC [openHABian] Storing configuration… OK
2018-03-13_22:53:36_UTC [openHABian] Changing default username and password… OK
2018-03-13_22:53:54_UTC [openHABian] Setting up Ethernet connection… OK
2018-03-13_22:53:54_UTC [openHABian] Ensuring network connectivity… OK
2018-03-13_22:53:54_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-05-25_09:25:01_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2019-05-25_09:26:55_UTC [openHABian] Initial setup exiting with an error!
Edit2: I try" sudo apt update && sudo apt upgrade" and “sudo /boot/first-boot.sh” and the same error. Change to other PSU, and Y power cable to USB/SSD.
