- Platform information:
- Hardware: x64
- OS: Windows 10
- Java Runtime Environment: 1.8.0_251
- openHAB version: 2.5.6
- Issue of the topic: Hello all, I’ve followed the instructions here: https://www.openhab.org/v2.2/docs/developer/development/ide.html and I get the errors below listed in Eclipse, after doing a Clean. Any idea how to fix this?
Description | Resource | Path | Location | Type |
Project ‘org.openhab.core.model.item’ is missing required source folder: ‘model’ | org.openhab.core.model.item | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.persistence’ is missing required source folder: ‘model’ | org.openhab.core.model.persistence | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.rule’ is missing required source folder: ‘model’ | org.openhab.core.model.rule | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.script.tests’ is missing required source folder: ‘src/main/resources’ | org.openhab.core.model.script.tests | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.script’ is missing required source folder: ‘model’ | org.openhab.core.model.script | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.sitemap’ is missing required source folder: ‘model’ | org.openhab.core.model.sitemap | Build path | Build Path Problem | |
Project ‘org.openhab.core.model.thing’ is missing required source folder: ‘model’ | org.openhab.core.model.thing | Build path | Build Path Problem | |
Project ‘org.openhab.ui.habmin’ is missing required source folder: ‘web’ | org.openhab.ui.habmin | Build path | Build Path Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.item | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.persistence | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.rule | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.script | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.script.tests | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.sitemap | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.core.model.thing | Unknown | Java Problem | |
The project cannot be built until build path errors are resolved | org.openhab.ui.habmin | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.auth.oauth2client.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.automation.integration.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.automation.module.core.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.automation.module.script.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.automation.module.timer.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.automation.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.binding.xml.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.bom.openhab-core-index | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.core.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.discovery.mdns.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.discovery.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.discovery.usbserial.linuxsysfs.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.discovery.usbserial.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.dispatch.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.config.xml.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.ephemeris.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.io.rest.core.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.karaf | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.model.core.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.model.item.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.model.persistence.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.model.rule.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.model.thing.testsupport | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.storage.json.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.thing.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.thing.xml.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.boot is built. Cleaning and building all projects is recommended | org.openhab.core.voice.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.model.item.ide is built. Cleaning and building all projects is recommended | org.openhab.core.model.lsp | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.model.rule.runtime is built. Cleaning and building all projects is recommended | org.openhab.core.boot | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.model.thing.testsupport is built. Cleaning and building all projects is recommended | org.openhab.core.model.thing.tests | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.ui is built. Cleaning and building all projects is recommended | org.openhab.core.io.rest.sitemap | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.ui is built. Cleaning and building all projects is recommended | org.openhab.core.io.rest.ui | Unknown | Java Problem | |
The project cannot be built until its prerequisite org.openhab.core.ui is built. Cleaning and building all projects is recommended | org.openhab.core.ui.icon | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.item, which has build path errors | org.openhab.core.model.item.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.item, which has build path errors | org.openhab.core.model.item.runtime | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.persistence, which has build path errors | org.openhab.core.model.persistence.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.persistence, which has build path errors | org.openhab.core.model.persistence.runtime | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.rule, which has build path errors | org.openhab.core.model.rule.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.rule, which has build path errors | org.openhab.core.model.rule.runtime | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.script, which has build path errors | org.openhab.core.model.script.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.script, which has build path errors | org.openhab.core.model.script.runtime | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.sitemap, which has build path errors | org.openhab.core.model.sitemap.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.sitemap, which has build path errors | org.openhab.core.model.sitemap.runtime | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.sitemap, which has build path errors | org.openhab.core.ui | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.thing, which has build path errors | org.openhab.core.model.thing.ide | Unknown | Java Problem | |
The project was not built since it depends on org.openhab.core.model.thing, which has build path errors | org.openhab.core.model.thing.runtime | Unknown | Java Problem |
