Hi All
I’ve had an OH 2.5 (and older) install running for years. I want to test OH3 on a different Win 10 laptop before I migrate.
I made an initial mistake of installing JRE version 8 301 but the OH3 install went fairly OK until I tried to run start.bat. That threw lots of errors.
In trying to edit start.bat to see what it did I may have associated it by accident with notepad++
Now if I double-click on any .bat file I get a “Windows can’t find the file” error:
I can still run it by launching from command prompt though.
This gave other similar errors. After a while, I read TFM properly and removed java and reinstalled Zulu java and updated the Env Variable JAVA_HOME to C:\Program Files\Zulu\zulu-11.
Still no luck, so I followed Karaf.bat, and this is throwing the following error:
C:\OpenHAB\runtime\bin>rem Retrieve java version
C:\OpenHAB\runtime\bin>for /F tokens=2-5 delims=.-_+" %j in (‘“C:\Program Files\Zulu\zulu-11\bin\java” -fullversion 2>&1’) do (if %j == 1 (set JAVA_VERSION=%k ) else (set JAVA_VERSION=%j ) )
‘“C:\Program Files\Zulu\zulu-11\bin\java” -fullversion 2>&1’ is not recognized as an internal or external command,
operable program or batch file.
8 was unexpected at this time.
C:\OpenHAB\runtime\bin>if GTR 8 (
Now I don’t know whether this is a problem launching .bat files or a problem with Java or JAVA_HOME.
Any ideas?
Cheers
Andrew
