I have been using OH2 a couple months. I did an initial test setup on a raspberry PI, got through the configuration, and even have a (mostly) complete UI using HABpanel. Thank you to all the developers who have contributed to making this package!
I am about to move to using a NUC mini-pc that I have, instead of using the PI. I know that there is a release candidate for OH2, but it isn’t out yet. When I started I had done the setup using the openhab2-offline packages, pointing at the snapshot repository. I had to move that over to the openhab2 package when that change was made, but I believe I am still pointing at the snapshot repo. When this happened, I had to remove the old packages and put in the new ones, since they had a different name.
My question is, in setting up the new machine, what is the transition plan once OH2 is released? I would prefer to just set this up with the ‘release’ package repo, so that I can do the setup, and once the final version is out, I can just do an update. It looks like the docs still show a testing and and unstable repository. I’m just trying to avoid extra work if I do the setup now, and have to change repos, and possibly uninstall and reinstall packages when the release actually happens.
