Hi, I am running on OH3.2 on a Raspi4. I got my Fritz.box connected via the TR064 binding following the posts in the forum. Worked well. I get values as you can see in the log file on some parameters.
What I am interested most is the parameter “current downstream bandwidth”. Strange enough this does not change. Here is a graph of the max downstream bandwidth, btw compared with an OOKLA Speedtest running on my Raspi.
As you can see there is only 1 green point from the current downstream rate (=Fritz.box download speed), but no further data points, while the max downstream rate parameter of the Fritz.box shows regular changes in values. Any idea why the current downstream is not changing values?
My setup: OH3.2, Raspi4, Grafana&Influx persistence.
The config of the current downstream rate:
What am I up for: as you can see the OOKLA speedtest on the Raspi shows repeated problems during the day. I want to get more data to single out the problem and wanted to compare the data rate on the Fritz box with the OOKLA on Raspi.
BR
a
runtimeInfo:
version: 3.2.0
buildString: Release Build
locale: de-AT
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.13
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.52+13-CA
osName: Linux
osVersion: 5.10.63-v7l+
osArchitecture: arm
availableProcessors: 4
freeMemory: 72979200
totalMemory: 324403200
bindings:
- coronastats
- fronius
- hue
- netatmo
- network
- speedtest
- systeminfo
- telegram
- tr064
clientInfo:
device:
ios: false
android: false
androidChrome: false
desktop: true
iphone: false
ipod: false
ipad: false
edge: false
ie: false
firefox: false
macos: true
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
webView: false
webview: false
standalone: false
os: macos
pixelRatio: 2
prefersColorScheme: light
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: N/A
language: de-DE
languages:
- de-DE
onLine: true
platform: MacIntel
screen:
width: 2560
height: 1440
colorDepth: 24
support:
touch: false
pointerEvents: true
observer: true
passiveListener: true
gestures: false
intersectionObserver: true
themeOptions:
dark: light
filled: true
pageTransitionAnimation: default
bars: filled
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko) Version/15.2 Safari/605.1.15
timestamp: 2022-01-29T09:14:32.098Z
