i´m still on oH 1.8.3 and trying to build a rule that saves the number of the last caller to another item.
But currently i´m only getting MyNumber##TheNumberThatCalled …
Items:
Switch fbKlingel "Telefon klingel [%s]" <phone> {fritzboxtr064="callmonitor_ringing"}
Call fbAnruf "Anruf von [%1$s]" <phone> {fritzboxtr064="callmonitor_ringing"}
Call fbAnrufName "Anruf von [%1$s]" <phone> {fritzboxtr064="callmonitor_ringing:resolveName"}
Call fbLastNumber "Letzter Anrufer: [%2$s]" <phone> // Dummy that shows the number
Call fbLastName "Letzter Anrufer: [%1$s]" <phone> // Dummy that shows the name
Sitemap:
Text item=fbAnruf // Just for debugging
Text item=fbAnrufName // Just for debugging
Text item=fbLastNumber
Text item=fbLastName
Rule:
import org.openhab.library.tel.types.CallType
import org.openhab.core.library.types.*
rule "Eingehender Anruf"
Item fbKlingel changed from OFF to ON
// Letzter Anrufer aktualisieren
val CallType call = fbAnruf.state as CallType
postUpdate(fbLastNumber, fbAnruf.state)
postUpdate(fbLastName, fbAnrufName.state)
logInfo("RuleLastCall", "Der Anruf von " + fbLastNumber.state + " wurde als Letzter Anrufer gespeichert.")
I tried to cut my own number and the “##” with remove and removeStart.
var fbLastCallNumber = fbAnruf.state
fbLastCallNumber = fbLastCallNumber.remove("0123456##")
This will result and the following Error:
2017-02-07 11:33:38.850 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Eingehender Anruf': The name '<XFeatureCallImplCustom>.removeStart(<XStringLiteralImpl>)' cannot be resolved to an item or type.
2017-02-07 11:34:41.845 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Eingehender Anruf': The name '<XFeatureCallImplCustom>.remove(<XStringLiteralImpl>)' cannot be resolved to an item or type.
I already used the removeEnd in other rules and it works fine…
I tried something different, but still got an error.
I´m using call.origNum:
postUpdate(fbLastNumber, call.origNum)
logInfo("RuleLastCall", "Der Anruf von " + call.origNum + " wurde als Letzter Anrufer gespeichert.")
2017-02-07 15:59:50.569 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Eingehender Anruf': Could not invoke method: org.openhab.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,java.lang.Number) on instance: null
This part is working fine:
Does you last call stick on the sitemap?
I have used your exact example, and the values in “Anruf von:” disappear after the caller hangs up (that is, the call was not accepted). Does the latter fact matter?
Thank you kindly
What is different to your previous post:
fbLastNumber and fbLastName are String items now – but it does not matter with regard to my outcome.
… and you are not getting this error (in openhab.log)?
2017-03-04 16:46:49.272 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Eingehender Anruf': Cannot cast org.openhab.library.tel.types.CallType to void
I have copied your rule, removed mine, and I get this error and the number does not stick – as in, when I hang up, the numbers disappear.
Yes, I am on 1.8.3 too – and only wonder why mine does not work.
What I just noticed too:
fbLastNumber and fbLastName are String items now, AND changed to [%s] instead of [%1$s].
This solved the issue with the number not sticking – Now it does!
Thank you very much…
Because the 7490 does not resolve the name; I deleted the second phone book, and imported it into the default phone book… which still did not resolve the number.
However, deleting the org.openhab.binding.fritzboxtr064-1.8.3.jar and adding it again, triggered this:
2017-03-04 17:18:18.962 [INFO ] [.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been shut down
2017-03-04 17:18:21.903 [INFO ] [.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2017-03-04 17:18:22.088 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Downloading phonebook ID 0
2017-03-04 17:18:23.129 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Callmonitor Thread [45770] attempting connection to FritzBox on 192.168.1.1:1012..
2017-03-04 17:18:23.133 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Connected to FritzBox on 192.168.1.1:1012
2017-03-04 17:18:41.370 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Trying to resolve number 0411511002 to name comparing 7 characters
2017-03-04 17:18:41.378 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Trying to resolve number 0411511002 to name comparing 7 characters
2017-03-04 17:18:41.383 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - found name match MaxG in phonebook by comparing 2001151140 with 2001151
2017-03-04 17:18:42.401 [WARN ] [ore.internal.items.ItemUpdater] - InstantiationException on org.openhab.core.library.types.StringType
2017-03-04 17:18:44.634 [INFO ] [nhab.model.script.RuleLastCall] - Der Anruf von 0411511002 (MaxG (Mobile)) wurde als Letzter Anrufer gespeichert.
with the interesting part being: 2017-03-04 17:18:22.088 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Downloading phonebook ID 0
I am glad I remembered seeing this before… phonebook id 0
One thing at the time (at least for me)… if 1.8.3 is working, then I need to replicate this first… then go explorer newer things.
I modified your version to the following:
val String LastCallNumber = call.destNum.toString()
val String LastCallName = fbAnrufName.state.toString()
LastCallName = LastCallName.removeStart("0754246505##")
postUpdate(fbLastNumber, LastCallNumber)
postUpdate(fbLastName, LastCallName)
logInfo("RuleLastCall", "Last call from " + LastCallNumber + " --> " + LastCallName)
… and this works without any errors in openhab.log
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
// Daten des CallType auslesen
// Die Variablen anlegen und mit der Nummer bzw. Namen des Anrufers füllen
// Die eigene Rufnummer aus der Variable entfernen
LastCallName = LastCallName.removeStart("1234567##")
// Prüfen ob der Anrufer unbekannt ist
if(LastCallName.startsWith("Name not found for"))
// Den Namen mit Unbekannt füllen
LastCallName = "Unbekannt"
// Die Daten in die Items eintragen
logInfo("RuleLastCall", "Der Anruf von " + LastCallNumber + " (" + LastCallName + ")" + " wurde als Letzter Anrufer gespeichert.")
1234567 = your number
Maybe check the log which number is used.
And just for the heck of it, further simplification:
from
// Den Namen mit Unbekannt füllen und die Daten in die Items eintragen
else
to
if (LastCallName.startsWith("Name not found for")) {
I have the problem that since I am working with openhab2 the rule to resolve the caller Name/Number ends in a failure. Now I have tried your rule with nearly the same result:
Rule 'Eingehender Anruf': void
What is the problem? Are there any changes in openhab2 in relation to the variable CallType?
Hi Johannes,
indeed there was a change in OH2: The CallType Type has been depreciated and is not used any more.
You will need to change your rule like so:
val incCall = fboxIncomingCallResolved.state as StringListType
val callerNumber = incCall.getValue(1)
var Anrufer = callerNumber.replace("Name not found for"," ")
Designer will complain and mark the line red; just ignore this it will run just fine.
HTH,
-OLI
Hi Oli,
thank you for your fast response. But please explain me, which part of the old rule I have to replace with your new expression? I have tried a few combination but without success.
Item fboxRinging changed from OFF to ON
val incCall = fbAnruf.state.state as StringListType
postUpdate(fblastNumber, callerNumber)
postUpdate(fbLastName, Anrufer)
logInfo("RuleLastCall", "Der Anruf von " + callerNumber + " (" + Anrufer + ")" + " wurde als Letzter Anrufer gespeichert.")
End in the following error:
19:35:19.264 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Eingehender Anruf': An error occured during the script execution: The name '<XMemberFeatureCallImplCustom>.state' cannot be resolved to an item or type.
Mhhhhhhh you are right Oli, thank you! Perfect!
One more question, How I can use the Name for an item when the name is saved in the phonebook.
A combination of your solution and the solution mentioned in this post does not run. Can you give me a hint?
Glad you got it working.
But i’mnot sure what you want to achieve…do you want an item for each phonebook entry which is named like the phonebook entry? so you can keep a record how often someone called?
The result of the rule should give me the following Info:
Der Anruf von 1234567890 (“Caller Name from fritzbox phonebook”) wurde als Letzter Anrufer gespeichert.
With the actually solution I get:
Der Anruf von 1234567890 (1234567890) wurde als Letzter Anrufer gespeichert.
val callerNumber and var Anrufer give me the same information (the caller number)
The solution from Max and Michael should give also the Name of the caller if saved at the intern phonebook of the fritzbox. The item “{fritzboxtr064=“callmonitor_ringing:resolveName”}” will give these information with an expression where you can extract the caller name.
I hope you understand my problem now.
