FritzBox AVM Binding
Hi I am a new user, so no clue if I make this ok.
I found out that the message:
Cannot connect to FRITZ!Box Call Monitor - make sure to enable it by dialing ‘#96*5’!
Is might be not correct anymore on my fritzbox 6591 Cable I need to type in
#965
the little axterix * cost me sometime to find it. When I used “#965” the box said call monitoring enabled and all is working.
Might be this helps others.
sorry I do not understand why the ‘*’ is disapearing in the text. So the code is
#965
after the six must be a * asterix and after the 5 as well the one after the 5 is not show in the error message
Cheers
Franz
