maxx92
(Marc Tanner)
April 25, 2018, 7:26pm
1
Hi all
Just a note that the Fritzbox binding has uninstalled ALL my bindings! This was reproduced 3 times. For me this is utterly unacceptable. Did anyone notice the same ugly behaviour?
sihui
(SiHui)
April 26, 2018, 9:28am
2
Please check your addons.cfg for any entries: you cannot install bindings via addons.cfg AND PaperUI at the same time. This would lead to the problem you mentioned.
maxx92
(Marc Tanner)
April 30, 2018, 2:45pm
3
actually that was not the problem. i only had bindings via paperUI at work, no double entries in one and the other… as explained, happened 3 times on new installations. annoying like hell if all your bindings are just deinstalled. i could watch them go in the lower right corner. viruses usually do these types of stuff.
binderth
(Thomas Binder)
April 30, 2018, 3:16pm
4
which fritzbox-binding do you mean?
I have fritzboxtr0641 (https://docs.openhab.org/addons/bindings/fritzboxtr0641/readme.html ) running without a problem. Usually what you describe happens as sihui already said, if you mix addons.cfg and PaperUI installations.
sihui
(SiHui)
April 30, 2018, 4:26pm
6
Yeah, looks like a fixed bug:
opened 01:28PM - 21 Jan 18 UTC
closed 11:58AM - 07 Mar 18 UTC
bug
bounty
critical
On openHAB 2.2.0 Release Build on RaspberryPi, I **installad a new binding (wemo… ) and immediatly afterwards all other installed bindings were automatically uninstalled.** The system had been running reliably for a week prior. (Later... I reinstalled the missing bindings and the previously configured things worked again. Doing all of this via PaperUI)
2018-01-21 17:41:46.257 [thome.event.ExtensionEvent] - Extension 'binding-wemo' has been installed.
2018-01-21 17:42:00.092 [hingStatusInfoChangedEvent] - 'chromecast:audiogroup:9002b144-c528-4295-9bc2-b02b82a6c2aa' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:00.136 [hingStatusInfoChangedEvent] - 'chromecast:audiogroup:9002b144-c528-4295-9bc2-b02b82a6c2aa' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:00.150 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:bb211de1906cf4b1800dfb5a5fa6db71' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:00.177 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:bb211de1906cf4b1800dfb5a5fa6db71' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:00.196 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:f3ceb2b04d95a2fd75e4841f2b91bbd3' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:00.250 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:f3ceb2b04d95a2fd75e4841f2b91bbd3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:00.259 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:9fb7f9a08a01ddf4287b098b067cfe4e' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:00.263 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:9fb7f9a08a01ddf4287b098b067cfe4e' changed from UNINITIALIZED to OFFLINE
2018-01-21 17:42:00.272 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:9fb7f9a08a01ddf4287b098b067cfe4e' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:00.296 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:1066a6e71f14cb893550bc5e4fb3db48' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:00.314 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:1066a6e71f14cb893550bc5e4fb3db48' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:00.486 [thome.event.ExtensionEvent] - Extension 'binding-chromecast' has been uninstalled.
2018-01-21 17:42:05.930 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Main_Zone' has been updated.
2018-01-21 17:42:06.032 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Zone_2' has been updated.
2018-01-21 17:42:12.433 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Main_Zone' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:12.457 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Main_Zone' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:12.471 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Zone_2' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:12.480 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0de716c4c:Zone_2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:12.497 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0de716c4c' changed from ONLINE to UNINITIALIZED
2018-01-21 17:42:12.502 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0de716c4c' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:12.619 [thome.event.ExtensionEvent] - Extension 'binding-yamahareceiver' has been uninstalled.
2018-01-21 17:42:24.141 [thome.event.ExtensionEvent] - Extension 'binding-mqtt1' has been uninstalled.
2018-01-21 17:42:37.328 [hingStatusInfoChangedEvent] - 'samsungtv:tv:74919c1d_dbc8_da2a_a081_e37c2ddea49e' changed from OFFLINE to UNINITIALIZED
2018-01-21 17:42:37.343 [hingStatusInfoChangedEvent] - 'samsungtv:tv:74919c1d_dbc8_da2a_a081_e37c2ddea49e' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-01-21 17:42:37.445 [thome.event.ExtensionEvent] - Extension 'binding-samsungtv' has been uninstalled.
2018-01-21 17:43:11.290 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from UNINITIALIZED to INITIALIZING
2018-01-21 17:43:11.333 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from INITIALIZING to OFFLINE
2018-01-21 17:43:47.331 [.ItemChannelLinkAddedEvent] - Link 'LightSwitch1-wemo:MZ100:ba565258:state' has been added.
2018-01-21 17:44:12.973 [ome.event.ItemCommandEvent] - Item 'LightSwitch1' received command ON
2018-01-21 17:44:12.989 [vent.ItemStateChangedEvent] - LightSwitch1 changed from NULL to ON
2018-01-21 17:45:27.079 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from OFFLINE to REMOVING
2018-01-21 17:45:27.093 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from REMOVING to REMOVED
2018-01-21 17:45:27.162 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from REMOVED to UNINITIALIZED
2018-01-21 17:45:27.211 [hingStatusInfoChangedEvent] - 'wemo:MZ100:ba565258' changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)`
Indeed, this happed to mee as well.
I wondered, why i suddenly could not control anything over the app, but everything works fine over google assistant.
As i took a look @ openhab PaperUI, i saw all binding were gone …
Didn’t know the reason till now
