FritzBox Binding without WLAN channels etc
I am using OH4.3 where I added the FritzBox and TR064 binding in order to enable/disable the WLAN. After I setup both binding I can see that both things are online (green).
When I open the channels I see only this:
*** online**
*** pingtime**
*** lastseen**
Question:
Why I can not find all other channels? I also checked under “advanced” but only those three are available.
You need to read the Binding docs more carefully.
Without seeing your Thing config, I assume you only have the TR064 Bridge Thing for your Fritz!Box.
The “missing” channels are listed under the “subdevicelan”
Therefore you need to have the subdevicelan Thing properly configured.
Either create a new Thing by selecting the TR064 Binding and hit scan at the top or create it manually.
Thanks for the reply… Now it works and I could add the missing channels!
:slight_smile:
