Here is the log of the binding,containing the response from the fritzbox:
21:01:52.423 [DEBUG] [g.avmfritz.handler.DeviceListPolling] - polling fritzbox org.openhab.binding.avmfritz.config.AvmFritzConfiguration@12d319[IP=192.168.178.1,port=<null>,proto=http,user=<null>,password=,pollingInterval=15,asyncTimeout=10000,syncTimeout=2000]
21:01:52.428 [DEBUG] [ternal.hardware.FritzahaWebInterface] - GETting URL http://192.168.178.1/webservices/homeautoswitch.lua?switchcmd=getdevicelistinfos&sid=27fe605ec5a48cce
21:01:53.058 [DEBUG] [nal.hardware.FritzahaContentExchange] - HTTP response 200
21:01:53.060 [DEBUG] [nal.hardware.FritzahaContentExchange] - HTTP response 200
21:01:53.062 [DEBUG] [nal.hardware.FritzahaContentExchange] - response complete: <devicelist version="1"><device identifier="10971 0470592" id="16" functionbitmask="320" fwversion="03.66" manufacturer="AVM" productname="Comet DECT"><present>1</present><name>Heizung Wohnzimmer</name><temperature><celsius>245</celsius><offset>0</offset></temperature><hkr><tist>49</tist><tsoll>48</tsoll><absenk>30</absenk><komfort>44</komfort></hkr></device><device identifier="08761 0267918" id="17" functionbitmask="896" fwversion="03.59" manufacturer="AVM" productname="FRITZ!DECT 200"><present>1</present><name>Steckdose TV</name><switch><state>1</state><mode>manuell</mode><lock>0</lock></switch><powermeter><power>82820</power><energy>91788</energy></powermeter><temperature><celsius>245</celsius><offset>0</offset></temperature></device></devicelist>
21:01:53.248 [DEBUG] [.binding.avmfritz.handler.BoxHandler] - set device model: org.openhab.binding.avmfritz.internal.ahamodel.DeviceModel@41f9cb[ain=109710470592,bitmask=320,isDectRepeater=false,isPowermeter=false,isTempSensor=true,isSwitchableOutlet=false,isHeatingThermostat=true,id=16,manufacturer=AVM,productname=Comet DECT,fwversion=03.66,present=1,name=Heizung Wohnzimmer,<null>,<null>,org.openhab.binding.avmfritz.internal.ahamodel.TemperatureModel@db2253[celsius=24.5,offset=0.0],org.openhab.binding.avmfritz.internal.ahamodel.HeatingModel@1d640ef[tist=24.5,tsoll=24.0,absenk=15.0,komfort=22.0,lock=<null>,errorcode=<null>,batterylow=<null>,nextchange=<null>]]
21:01:53.252 [DEBUG] [.binding.avmfritz.handler.BoxHandler] - update thing avmfritz:Comet_DECT:192_168_178_1:109710470592 with device model: org.openhab.binding.avmfritz.internal.ahamodel.DeviceModel@41f9cb[ain=109710470592,bitmask=320,isDectRepeater=false,isPowermeter=false,isTempSensor=true,isSwitchableOutlet=false,isHeatingThermostat=true,id=16,manufacturer=AVM,productname=Comet DECT,fwversion=03.66,present=1,name=Heizung Wohnzimmer,<null>,<null>,org.openhab.binding.avmfritz.internal.ahamodel.TemperatureModel@db2253[celsius=24.5,offset=0.0],org.openhab.binding.avmfritz.internal.ahamodel.HeatingModel@1d640ef[tist=24.5,tsoll=24.0,absenk=15.0,komfort=22.0,lock=<null>,errorcode=<null>,batterylow=<null>,nextchange=<null>]]
21:01:53.254 [DEBUG] [.binding.avmfritz.handler.BoxHandler] - about to update thing avmfritz:Comet_DECT:192_168_178_1:109710470592 from device org.openhab.binding.avmfritz.internal.ahamodel.DeviceModel@41f9cb[ain=109710470592,bitmask=320,isDectRepeater=false,isPowermeter=false,isTempSensor=true,isSwitchableOutlet=false,isHeatingThermostat=true,id=16,manufacturer=AVM,productname=Comet DECT,fwversion=03.66,present=1,name=Heizung Wohnzimmer,<null>,<null>,org.openhab.binding.avmfritz.internal.ahamodel.TemperatureModel@db2253[celsius=24.5,offset=0.0],org.openhab.binding.avmfritz.internal.ahamodel.HeatingModel@1d640ef[tist=24.5,tsoll=24.0,absenk=15.0,komfort=22.0,lock=<null>,errorcode=<null>,batterylow=<null>,nextchange=<null>]]
21:01:53.267 [ERROR] [.binding.avmfritz.handler.BoxHandler] -
java.lang.NullPointerException
at org.openhab.binding.avmfritz.handler.BoxHandler.updateThingFromDevice(BoxHandler.java:194)[243:org.openhab.binding.avmfritz:2.1.0.201702022035]
at org.openhab.binding.avmfritz.handler.BoxHandler.addDeviceList(BoxHandler.java:133)[243:org.openhab.binding.avmfritz:2.1.0.201702022035]
at org.openhab.binding.avmfritz.internal.hardware.callbacks.FritzAhaUpdateXmlCallback.execute(FritzAhaUpdateXmlCallback.java:70)[243:org.openhab.binding.avmfritz:2.1.0.201702022035]
at org.openhab.binding.avmfritz.internal.hardware.FritzahaContentExchange.onComplete(FritzahaContentExchange.java:71)[243:org.openhab.binding.avmfritz:2.1.0.201702022035]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:193)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:185)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:453)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:400)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:266)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1487)[71:org.eclipse.jetty.http:9.2.19.v20160908]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1245)[71:org.eclipse.jetty.http:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:156)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:117)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:69)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:89)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:123)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
21:01:53.275 [DEBUG] [.binding.avmfritz.handler.BoxHandler] - set device model: org.openhab.binding.avmfritz.internal.ahamodel.DeviceModel@5c5dab[ain=087610267918,bitmask=896,isDectRepeater=false,isPowermeter=true,isTempSensor=true,isSwitchableOutlet=true,isHeatingThermostat=false,id=17,manufacturer=AVM,productname=FRITZ!DECT 200,fwversion=03.59,present=1,name=Steckdose TV,org.openhab.binding.avmfritz.internal.ahamodel.SwitchModel@17662ca[state=1,mode=manuell,lock=0],org.openhab.binding.avmfritz.internal.ahamodel.PowerMeterModel@98148d[power=82.820,energy=91.788],org.openhab.binding.avmfritz.internal.ahamodel.TemperatureModel@19efc09[celsius=24.5,offset=0.0],<null>]
What do you exactly mean by “automatic profiles”?
