I’m using Openhab 2.2 and have some problems with the dsl-stats of the TR-064 binding.
When I was still on OH2.1 the value
fritzboxtr064="dslDownstreamCurrRate"
was not defined - it seems to be with the version of the binding included in OH2.2 but it does not return the current DSL rate but the synced Maximum rate.
I use TR064 for presence detection and would like to use it as well to show my current down- and upstream.
Are the two values DSL Upstream Current and DSL Downstream Current reflect your actual Downstream/Upstream or do they show the currently synced DSL rates?
In my case all values were static so I switched over to a python-script that I run through the Exec-Binding every 10 seconds.
Flo, you are right! These are only the static DSL rates and NOT the real live one depending on actual down- or upload stream. I also used to use severel month ago the python fritzconnection to get live values every 2 seconds. How exactly do you get your live down- and upstream rates - may you share some code snippets? regards Dirk
It uses pysimplesoap wich can be installed trough pip3 which is part of python3 (which is the only component preinstalled on openhabian). So installed these componentes with these commands:
I basically did the same for upstream as I don’t know by now how to split a scripts output to two different items. There certainly is an easy way to do this - thus I just don’t now it. So if anybody can shed some light on this I’d be able to save one script execution every 30 seconds…
