It works now.
Only difference: I disabled and reenabled the Bridge AND the Inverter Thing!
One of the many different attempts to make it work …
Seems like config updates are not handled properly by the Fronius Thing handlers … I have created [fronius] Config updates are not handled properly by Thing handlers · Issue #18123 · openhab/openhab-addons · GitHub.
I updated the Symo Gen24 10 to V 1.34.6-1
Restarted oh, but got the same error again.
2025-01-18 20:22:55.561 [WARN ] [l.handler.FroniusSymoInverterHandler] - Failed to set battery control to force battery charge
org.openhab.binding.fronius.internal.api.FroniusCommunicationException: Unable to connect
at org.openhab.binding.fronius.internal.api.FroniusConfigAuthUtil.login(FroniusConfigAuthUtil.java:253) ~[?:?]
at org.openhab.binding.fronius.internal.api.FroniusBatteryControl.setTimeOfUse(FroniusBatteryControl.java:113) ~[?:?]
at org.openhab.binding.fronius.internal.api.FroniusBatteryControl.reset(FroniusBatteryControl.java:132) ~[?:?]
at org.openhab.binding.fronius.internal.api.FroniusBatteryControl.forceBatteryCharging(FroniusBatteryControl.java:171) ~[?:?]
at org.openhab.binding.fronius.internal.handler.FroniusSymoInverterHandler.forceBatteryCharging(FroniusSymoInverterHandler.java:153) ~[?:?]
at org.openhab.binding.fronius.internal.action.FroniusSymoInverterActions.forceBatteryCharging(FroniusSymoInverterActions.java:148) ~[?:?]
at org.openhab.binding.fronius.internal.action.FroniusSymoInverterActions.forceBatteryCharging(FroniusSymoInverterActions.java:78) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:569) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1195) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1170) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1156) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1101) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:881) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:137) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.eval(AbstractScriptModuleHandler.java:219) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:94) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:178) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:81) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1299) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:1057) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:86) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.binding.fronius.internal.api.FroniusCommunicationException: Failed to send login request
at org.openhab.binding.fronius.internal.api.FroniusConfigAuthUtil.performLoginRequest(FroniusConfigAuthUtil.java:177) ~[?:?]
at org.openhab.binding.fronius.internal.api.FroniusConfigAuthUtil.login(FroniusConfigAuthUtil.java:240) ~[?:?]
... 39 more
Caused by: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:732) ~[?:?]
at org.openhab.binding.fronius.internal.api.FroniusConfigAuthUtil.performLoginRequest(FroniusConfigAuthUtil.java:171) ~[?:?]
... 39 more
Caused by: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:164) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
at org.eclipse.jetty.http.HttpParser.handleContentMessage(HttpParser.java:596) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1723) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1552) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
... 1 more
It looks like there is an authorization error, HTTP vs. HTTPS?
Please enable debug logging, see above.
This is a TRACE in the fronius binding:
2025-01-18 20:55:27.556 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Getting authentication parameters
2025-01-18 20:55:27.556 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Sending login request to get authentication challenge
2025-01-18 20:55:27.562 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Parsing authentication challenge
2025-01-18 20:55:27.563 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Creating digest authentication header
2025-01-18 20:55:27.563 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Sending login request
2025-01-18 20:55:27.567 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - HTTP error on attempt #1 http://192.168.1.33/commands/Login?user=Technician
2025-01-18 20:55:28.071 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - HTTP error on attempt #2 http://192.168.1.33/commands/Login?user=Technician
2025-01-18 20:55:29.071 [DEBUG] [s.internal.api.FroniusConfigAuthUtil] - Failed connecting to http://192.168.1.33/commands/Login?user=Technician after 3 attempts.
... 40 more
... 1 more
2025-01-18 20:55:29.079 [WARN ] [l.handler.FroniusSymoInverterHandler] - Failed to set battery control to force battery charge
... 39 more
... 39 more
... 1 more
There is no difference if I use Technician, Customer, technician or customer
It should work with customer
or technician
(lowercase) if you provide the correct password. Make sure to disable and enable again both the bridge and the Thing after changing these settings.
I have created a PR that properly logs a warning about invalid credentials instead of the current stack trace: [fronius] Fix invalid credentials lead to unexpected exception by florian-h05 · Pull Request #18130 · openhab/openhab-addons · GitHub
Call me crazy, but it is working now, I changed nothing but restarted oh again.
Thanks for your help!
I have Fronius Symo gen 24 10kW inverter and a BYD 11.kWh battery.
Atm I´m using the Fronius binding.
Question:
Is there any way to controle the battery directly?
I want to set the battery to not discharge (or limited discharge like 5watt) as soon as my Tesla starts to charge.
Do you know if thats possible… I cant seem to find any option for this in the Fronius binding.
Yes, take a look at the Fronius - Bindings | openHAB.
You can do that by calling the hold battery charge action, and as soon as you want to reverse to normal behaviour, call the reset battery control action. Since 4.3, this is supported directly through UI rules, just click on show all actions and select them.
Hmm is this for OH 4.3 and later? I think I´m on an older 4.xx.
I´ll give it a try… But I might update OH first I guess
It was merged in July 2024, so yes, looks like 4.3
I just tried it and it works like a charme, thanks Florian!
@Kim_Andersen, there are examples in the binding docs, very nice to follow and easy to adapt.
Thanks alot… Thats good info…
Hopefully I may get some time to update my OH this ucoming weekend… And then I might need some help regarding the actions rules, as I think I´m becoming a bit rusty
