FroniusWattpilotHandler tried updating the thing status although the handler was already disposed
I have installed the Fronius Wattpilot binding and configures access to my wallbox. I was also able to successfully configure channels. But the binding is spamming my openhab log now with these messages:
2026-05-12 08:33:00.412 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler FroniusWattpilotHandler tried updating the thing status although the handler was already disposed.
2026-05-12 08:33:00.413 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler FroniusWattpilotHandler tried updating the thing status although the handler was already disposed.
2026-05-12 08:33:15.086 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler FroniusWattpilotHandler tried updating the thing status although the handler was already disposed.
2026-05-12 08:33:18.008 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler FroniusWattpilotHandler tried updating the thing status although the handler was already disposed.
I tried to set the log level of the binding to ERROR but this didn’t change anything.
I’m on openhab 5.1.4.
Anyone an idea?
suppressing warnings by lowering the log level isn’t really a solution …
I’ll have a look at the disposal logic, seems it has a bug.
Aha, this (Shelly Binding - #5254 by ErikDB) is then probably bound to the same issue?
Not the information you wanted, but this will be a per-binding issue.
A OH core item in every binding is the ThingHandler. It does the initialization() and also the dispose() method. If something doesn’t get disposed this warning will appear. An example is if a polling job is initialized and not disposed (when the Thing status changes), the polling will continue after the handler is disposed and the warnings will keep coming. I haven’t stumbled on all the issues, but if the thing is reinitialized, I’ve seen duplicate polling from two schedulers and continued warnings. Just an example
So there indeed was a bug and I’ve created a fix for it:
