So I am trying to get my FS20 switch running on OPENHAB2.2 on PI3b and now with an original Busware CUL.
I would say - I am close - but not yet successful!
Using the screen commando on ttyACM0 I am getting something like
FCD9B13123F
FCD9B131232
and the related switch switchs using the remot control.
So I am confirmed with my own calculation I did before for this switch and houscode
CD9B13
Yeah Works!!! Thanks a lot,
So at the end it was just the wrong logic I used in sitemap and items!!
New Questions from a Beginner:
Can I only use the FS20 items in BasicUI or also in e.g. HabPanel or PaperUI?
Can I combine Z-Wave Movement detector to switch the FS20 Switches maybe in HabPanel?
Do I need to enter a rule in HabPanel for this - Maybe somebody has an example for me?
And important here:
For others now the example with a working logic:
(I wasn´t successful using another non-busware CUL, just with the original busware CUL it´s working)
Thanks a lot, (Your answers are not really long:slight_smile:
So in the example “Item Presence_Mobile_John” could be a Zwave item and
"Wallplug_FF_LR_TV" could be FS20 switch?
Then these names used are my defined items doesn´t matter if FS20 or ZWAVE?
Can I flexible use such rules in all UIs means Paper, Basic and HabPanel?
Example:
rule "Wallplug_FF_LR_TV ON"
Item Presence_Mobile_John changed from OFF to ON
Wallplug_FF_LR_TV.sendCommand(ON)
rule "Wallplug_FF_LR_TV OFF"
Item Presence_Mobile_John changed from ON to OFF
Wallplug_FF_LR_TV.sendCommand(OFF)
