Hi, I see also the following in the logs :
17:43:05.725 [DEBUG] [org.openhab.io.gcal ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.id=480, service.bundleid=240, service.scope=bundle, service.pid=org.openhab.gcal, component.name=org.openhab.binding.gcal.eventdownloader, component.id=327} - org.openhab.io.gcal
17:43:06.077 [DEBUG] [org.openhab.binding.fs20 ] - BundleEvent STARTING - org.openhab.binding.fs20
17:43:06.085 [DEBUG] [b.binding.fs20.internal.FS20Activator] - FS20 binding has been started.
17:43:06.087 [DEBUG] [org.openhab.binding.fs20 ] - BundleEvent STARTED - org.openhab.binding.fs20
17:43:06.141 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.model.item.BindingConfigReader}={service.id=490, service.bundleid=196, service.scope=singleton} - org.openhab.core.compat1x
17:43:07.682 [DEBUG] [org.openhab.binding.fs20 ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.fs20.FS20BindingProvider}={service.id=489, service.bundleid=250, service.scope=bundle, component.name=org.openhab.binding.fs20.genericbindingprovider, component.id=337} - org.openhab.binding.fs20
17:43:07.693 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent [unknown:512] - org.openhab.io.transport.cul
17:43:07.697 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTING - org.openhab.io.transport.cul
17:43:07.704 [DEBUG] [openhab.io.transport.cul.CULActivator] - CUL transport has been started.
17:43:07.708 [INFO ] [.eclipse.smarthome.model.script.Sauna] - Sauna Schalter is aus, tue nichts
17:43:07.723 [DEBUG] [.io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl for device type serial
17:43:07.729 [DEBUG] [.io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.network.CULNetworkHandlerImpl for device type network
17:43:07.731 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTED - org.openhab.io.transport.cul
17:43:07.746 [DEBUG] [hab.binding.fs20.internal.FS20Binding] - Activating FS20 binding
17:43:07.749 [WARN ] [.io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
17:43:07.753 [DEBUG] [hab.binding.fs20.internal.FS20Binding] - Received new config
17:43:07.753 [DEBUG] [org.openhab.binding.fs20 ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={service.id=491, service.bundleid=250, service.scope=bundle, event.topics=openhab/command/*, service.pid=org.openhab.fs20, component.name=org.openhab.binding.fs20.binding, component.id=336} - org.openhab.binding.fs20
17:43:07.757 [DEBUG] [.io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/ttyACM0 in mode SLOW_RF
17:43:07.757 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTING - org.openhab.binding.weather
17:43:07.759 [DEBUG] [.io.transport.cul.internal.CULManager] - Searching class for device type serial
17:43:07.764 [DEBUG] [weather.internal.bus.WeatherActivator] - Weather binding has been started.
17:43:07.765 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTED - org.openhab.binding.weather
17:43:07.775 [DEBUG] [.internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/ttyACM0
17:43:07.800 [DEBUG] [org.openhab.core.compat1x ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.model.item.BindingConfigReader}={service.id=493, service.bundleid=196, service.scope=singleton} - org.openhab.core.compat1x
17:43:07.828 [WARN ] [.io.transport.cul.CULLifecycleManager] - Can't open CUL
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:111) ~[251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.open(AbstractCULHandler.java:163) ~[251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.io.transport.cul.internal.CULManager.createNewHandler(CULManager.java:150) ~[251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.io.transport.cul.internal.CULManager.getOpenCULHandler(CULManager.java:85) ~[251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:86) [251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74) [251:org.openhab.io.transport.cul:1.13.0]
at org.openhab.binding.fs20.internal.FS20Binding.updated(FS20Binding.java:94) [250:org.openhab.binding.fs20:1.13.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1102) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1058) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4]
Caused by: gnu.io.NoSuchPortException
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) ~[?:?]
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:87) ~[?:?]
... 14 more
17:43:07.880 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=491, bundle=250/mvn:org.openhab.binding/org.openhab.binding.fs20/1.13.0]: Unexpected problem updating configuration org.openhab.fs20
at org.openhab.io.transport.cul.CULLifecycleListenerListenerRegisterer.open(CULLifecycleListenerListenerRegisterer.java:21) ~[?:?]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:92) ~[?:?]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74) ~[?:?]
at org.openhab.binding.fs20.internal.FS20Binding.updated(FS20Binding.java:94) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) ~[9:org.apache.felix.configadmin:1.9.4]
17:43:08.138 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={service.id=494, service.bundleid=259, service.scope=bundle, event.topics=openhab/command/*, service.pid=org.openhab.weather, component.name=org.openhab.binding.weather, component.id=338} - org.openhab.binding.weather
17:43:08.140 [WARN ] [g.weather.internal.bus.WeatherBinding] - Unable to find any configuration settings for weather binding. Check openhab.cfg.
17:43:08.143 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=494, bundle=259/mvn:org.openhab.binding/org.openhab.binding.weather/1.13.0]: Updating property weather of configuration org.openhab.weather caused a problem: Unable to find any configuration settings for weather binding. Check openhab.cfg.
org.osgi.service.cm.ConfigurationException: weather : Unable to find any configuration settings for weather binding. Check openhab.cfg.
at org.openhab.binding.weather.internal.bus.WeatherBinding.updated(WeatherBinding.java:76) ~[?:?]
17:43:08.150 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.weather.WeatherBindingProvider}={service.id=492, service.bundleid=259, service.scope=bundle, component.name=org.openhab.binding.weather.genericbindingprovider, component.id=339} - org.openhab.binding.weather
17:43:08.196 [DEBUG] [g.weather.internal.gfx.WeatherServlet] - Starting up weather servlet at /weather
17:43:08.260 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.version=1.13.0, osgi.web.contextpath=/, service.id=495, osgi.web.symbolicname=org.openhab.binding.weather, service.bundleid=259, service.scope=singleton, osgi.web.contextname=custom} - org.openhab.binding.weather
17:43:08.669 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:systemBroker:embedded-mqtt-broker' changed from UNINITIALIZED to INITIALIZING
17:43:08.692 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:systemBroker:embedded-mqtt-broker' changed from INITIALIZING to ONLINE
17:43:08.969 [INFO ] [smarthome.event.RuleAddedEvent ] - Rule '4be8b357-70fc-409c-8498-de1de6d11162' has been added.
17:43:08.977 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 4be8b357-70fc-409c-8498-de1de6d11162 updated: UNINITIALIZED
17:43:09.080 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 4be8b357-70fc-409c-8498-de1de6d11162 updated: IDLE
17:43:09.249 [ERROR] [automation.module.script.defaultscope] - bundle org.eclipse.smarthome.automation.module.script.defaultscope:0.10.0.oh240 (273)[org.eclipse.smarthome.automation.module.script.defaultscope.internal.DefaultScriptScopeProvider(353)] : The addThingActions method has thrown an exception
at org.eclipse.smarthome.automation.module.script.defaultscope.internal.DefaultScriptScopeProvider.addThingActions(DefaultScriptScopeProvider.java:125) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1809) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.bindDependency(DependencyManager.java:1637) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.bind(DependencyManager.java:1625) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:301) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1801) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
17:43:09.266 [ERROR] [automation.module.script.defaultscope] - bundle org.eclipse.smarthome.automation.module.script.defaultscope:0.10.0.oh240 (273)[org.eclipse.smarthome.automation.module.script.defaultscope.internal.DefaultScriptScopeProvider(353)] : The addThingActions method has thrown an exception
17:43:10.354 [DEBUG] [org.openhab.core ] - BundleEvent STARTING - org.openhab.core
17:43:12.390 [DEBUG] [org.openhab.core ] - BundleEvent STARTED - org.openhab.core
