Yes, unless you undo the firmware update. I think this is not possible, but I don’t know.
I only can find this newest firmware here:
What happens when you load:
http://192.168.188.88/iweb.html ?? (I guess: NOTHING!!)
With an older firmware you would see the following (after login):
(Sorry, it’s in german!)
If no website is available, you could try the following:
Inside the above mentioned download folder, inside the zip file, there is a file called: lpb_web_ew_V1.0.14.bin
(1.0.14 is the same version as you can see in my system settings in 2nd screenshot above)
This is the “web interface”. Maybe you can upload it again onto your socket.
ATTENTION!! YOU DO IT ON YOUR OWN RISK! MAYBE YOU WILL DESTROY YOUR SOCKET!
If you want to try it (on your own risk!!), here is a short manual:
Download above .zip. Unzip only lpb_web_ew_V1.0.14.bin
to a folder e.g. C:\g-homa\
goto step 13 f: revert the steps in f. (uncomment) (eventually delete or comment the 3 lines from former attempts of step 13 g !)
goto step 13 c and run it again. Then again goto step 13 f. (comment again)
new step 13 g: fill in 1 new line after line 76:
send(new Buffer("AT+UPURL=file:///C:/g-homa/,lpb_web_ew_V1.0.14.bin\r")); //upload old webpage firmware
Attention: the “,” inside the above path C:/g-homa/,lpb_web_ew_V1.0.14.bin
is from above documentation (page 21). If it’s not running, try it without “,”.
BUT AGAIN: ALL ON YOUR OWN RISK! I’VE NEVER TRIED THIS! SO, NO WARRANTY!
