Nognog
(Daniel N.)
February 11, 2019, 9:19pm
1
Platform information: RPI3
OS: openhabian latest
openHAB version: Openhab 2.4 latest
Hello everybody,
is it possible to detect presence (BLE) via an ESP32? I found some instructions, but I’m new to the field and I’m not quite sure.
I would like to detect a g-TAG with the ESP32 via Bluetooth (BLE) and send Informations (presence) via WLAN / MQTT to pi3 / openhab.
Is that possible? Does anyone have a step by step guide?
thanks for help
Daniel
Nognog
(Daniel N.)
February 16, 2019, 6:21pm
3
Hello everybody,
After a few hours, I got the ESP32 up and running. I still have the following problem, in the Mqtt comes the information about RSSI and distance, but above hab does not take this.
What am I doing wrong?
> home/presence/BLEGateway {"id":"7c:2f:80:8e:xx:xx","manufacturerdata":"▒4▒▒▒Ȼ▒","rssi":-74,"distance":5.270232}
> Number nogone_tag_rssi "Daniel Empfang [%d %%]" <wlan> (gPresenc) {mqtt="<[broker:home/presence/BLEGateway/7c2f808exxxx:state:JSONPATH($.rssi)]"}
> Number nogone_tag_dis "Daniel Entfernung [%.2f m]" <wlan> (gPresenc) {mqtt="<[broker:home/presence/BLEGateway/7c2f808exxxx:state:JSONPATH($.distance)]"}
thanks for help
vzorglub
(Vincent Regaud)
February 16, 2019, 6:25pm
4
This is mqttv1 syntax
Your are using openHAB 2.4. Which version of the mqtt binding are you using?
Nognog
(Daniel N.)
February 16, 2019, 6:28pm
5
I use the old MQTT V1.13.0
Nognog
(Daniel N.)
February 16, 2019, 6:58pm
7
broker.url=tcp://openhabxxxxxx:1883
broker.clientId=OpenHAB2
broker.user=openhabian
broker.pwd=xxxxxxxxxx
broker.qos=0
broker.retain=true
broker.async=false
All othe Sonoffs and shellys work, only the Data from ESP32 - Presenc dont work
vzorglub
(Vincent Regaud)
February 16, 2019, 7:04pm
8
Ok, so the problem is not MQTT…
Do you use an MQTT tool like MQTTfx?
What topics are being published by the ESP32 and what payloads? Exactly. Thanks
Nognog
(Daniel N.)
February 16, 2019, 7:11pm
9
oh sorry, in the Mqtt comes the information about RSSI and distance
home/presence/BLEGateway {“id”:“7c:2f:80:8e:xx:xx”,“manufacturerdata”:“▒4▒▒▒Ȼ▒”,“rssi”:-74,“distance”:5.270232}
but in openhab the items
don’t take the payload.
vzorglub
(Vincent Regaud)
February 16, 2019, 7:13pm
10
The topic is incorrect
{mqtt="<[broker:home/presence/BLEGateway:state:JSONPATH($.rssi)]"}
Nognog
(Daniel N.)
February 16, 2019, 7:18pm
11
Ok, what would that be the right topic?
{mqtt="<[broker:home/presence/BLEGateway…??
vzorglub
(Vincent Regaud)
February 16, 2019, 7:19pm
12
You posted it yourself above:
Nognog:
jimmyalias
(jimmy loyens)
December 13, 2019, 2:38am
13
Hello, can you post a link of the instructions you followed?
