A simple widget showing the status of a garage door (opened or closed) and a single button for activating the door’s operation.
The widget offers the following configuration options:
- Control Item: control Item to operate the gates.
- Command: the command to be sent to the Control Item on activation.
- Sensor Item: sensor Item to determine the gates open/close status.
- Sensor state when closed: The state of the Sensor Item when the door is closed. Any other state than closed or moving will be interpreted as opened.
- Sensor state when moving: The state of the Sensor Item when the door is moving. Any other state than closed or moving will be interpreted as opened.
- Title: text to show as title.
- Button Label: text to show on the button.
- Open Label: text to show on the status indicator if the gate is open.
- Moving Label: text to show on the status indicator while the gate is moving.
- Closed Label: text to show on the status indicator if the gate is closed.
Screenshots
The status badge when the door is opened:
The configuration:
Changelog
Version 0.2
- added support for an optional third state to be shown while the garage door/gates are for moving between open and close.
Version 0.1
- initial release
Resources
The YAML code for the widget:
uid: GarageDoorButton
tags:
- button
- cell
- garagedoor
- status
props:
parameters:
- context: item
description: Control Item to operate the gates.
label: Control Item
required: true
type: TEXT
groupName: items
- default: ON
description: The command to be sent to the Control Item on activation.
label: Command
required: true
type: TEXT
groupName: items
- context: item
description: Sensor Item to determine the gates open/close status.
label: Sensor Item
required: true
type: TEXT
groupName: items
- default: CLOSED
description: The state of the Sensor Item when the door is closed. Any other state than closed or moving will be interpreted as opened.
label: Sensor state when closed
required: true
type: TEXT
groupName: items
- default: MOVING
description: The state of the Sensor Item when the door is moving. Any other state than closed or moving will be interpreted as opened.
label: Sensor state when moving
required: false
type: TEXT
groupName: items
- default: Garage Door
description: Text to show as title.
label: Title
required: true
type: TEXT
groupName: labels
- default: Activate
description: Text to show on the button.
label: Button Label
required: true
type: TEXT
groupName: labels
- default: Open
description: Text to show on the status indicator if the gate is open.
label: Open Label
required: true
type: TEXT
groupName: labels
- default: Moving
description: Text to show on the status indicator when the gate is moving. Leave blank if your sensor item does not have a status for moving.
label: Moving Label
required: false
type: TEXT
groupName: labels
- default: Closed
description: Text to show on the status indicator if the gate is closed.
label: Closed Label
required: true
type: TEXT
groupName: labels
parameterGroups:
- name: items
label: Items
- name: labels
label: Labels
timestamp: Jan 23, 2023, 2:25:48 PM
component: f7-card
title: =props.title
slots:
default:
- component: f7-block
class: bog
style:
align-content: space-between
align-items: center
display: flex
flex-wrap: wrap
justify-content: flex-start
padding: 10px
slots:
default:
- component: oh-button
color: '=(items[props.sensor_item].state == props.sensor_state_closed) ? "green" : ((items[props.sensor_item].state == props.sensor_state_moving) ? "yellow" : "red")'
disabled: true
fill: true
outline: true
style:
margin: 10px
opacity: 1 !important
width: 100px
text: "=(items[props.sensor_item].state == props.sensor_state_closed) ? props.closed_label : ((items[props.sensor_item].state == props.sensor_state_moving) ? props.moving_label : props.open_label)"
action: command
actionCommand: =props.control_item_command
actionItem: =props.control_item
active: =(items[props.control_item].state === props.control_item_command)
outline: true
style:
margin: 10px
width: 100px
text: =props.button_label
