Gardena binding [2.5.13] water control - "device does not contain property"
Until a few days ago I was happily using the 2.5.5 Gardena binding, but then it started dropping the connection and throwing errors, so I’ve replaced it with 2.5.13(also tried everything else in between).
I use it with a Sensor (works fine) and a Watering valve. Latter seems to have issues with the newer versions.
https://openhab.jfrog.io/artifactory/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.gardena/2.5.13-SNAPSHOT/
It seems like, that although there’re a lot of (different from the older version or the documentation) parameters available from PaperUI, they don’t really exist anymore in the device or on Gardena’s side.
Could anyone maybe have a look at it?
@gerrieg
maybe?
Thanks a lot!
2021-06-14 16:08:18.086 [WARN ] [odel.deser.PropertyValueDeserializer] - Unsupported json value object, returning empty value
2021-06-14 16:08:18.089 [WARN ] [odel.deser.PropertyValueDeserializer] - Unsupported json value object, returning empty value
2021-06-14 16:08:18.099 [WARN ] [internal.handler.GardenaThingHandler] - Channel 'gardena:watering_computer:gardenasmarthomeaccount:5d6e1a75-8d81-44d3-aae3-37e35867b1a3:outlet#valve_open' cannot be updated as device does not contain property 'outlet:valve_open'
2021-06-14 16:08:18.102 [WARN ] [internal.handler.GardenaThingHandler] - Channel 'gardena:watering_computer:gardenasmarthomeaccount:5d6e1a75-8d81-44d3-aae3-37e35867b1a3:outlet#manual_override' cannot be updated as device does not contain property 'outlet:manual_override'
2021-06-14 16:08:18.105 [WARN ] [internal.handler.GardenaThingHandler] - Channel 'gardena:watering_computer:gardenasmarthomeaccount:5d6e1a75-8d81-44d3-aae3-37e35867b1a3:outlet#button_manual_override_time' cannot be updated as device does not contain property 'outlet:button_manual_override_time'
2021-06-14 16:08:18.108 [WARN ] [internal.handler.GardenaThingHandler] - Channel 'gardena:watering_computer:gardenasmarthomeaccount:5d6e1a75-8d81-44d3-aae3-37e35867b1a3:ambient_temperature#frost_warning' cannot be updated as device does not contain property 'ambient_temperature:frost_warning'
The 2.5 binding is no longer supported, please user the 3.x version. It is a complete rewrite and uses the official Gardena API
