I tried several things but nothing helped so I hope you have some additional ideas for my issues. Last year, all my gardena smart system worked well controlled by openhab using Openhab 2.3.
Now during the winter I updated openhab (2.5.2 and now in the hope of problem solving 2.5.3-1) and the gardena system with the newest software. All my sensors are working properly and are giving the correct values to my openhab system.
What does not work is watering with my irrigation control via openhab.
But watering is possible via the origina gardena app, so it donât seem to be a hardware or cloud service topic but in the interface between openhab and gardena.
When I activate one of the valves using the basic UI, in openhab everything seems to be correct in the first place but then a warning is coming up:
2020-03-22 20:37:45.443 [ome.event.ItemCommandEvent] - Item âGarten_IC_Hecke_Bewaesserungstimerâ received command 10
2020-03-22 20:37:45.468 [nt.ItemStatePredictedEvent] - Garten_IC_Hecke_Bewaesserungstimer predicted to become 10
2020-03-22 20:37:45.575 [vent.ItemStateChangedEvent] - Garten_IC_Hecke_Bewaesserungstimer changed from 0 to 10
2020-03-22 20:37:53.932 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Illegal status UNINITIALIZED. Bindings only may set UNKNOWN, ONLINE, OFFLINE or REMOVED.
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.ensureValidStatus(ThingManagerImpl.java:215) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.statusUpdated(ThingManagerImpl.java:185) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateStatus(BaseThingHandler.java:357) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateStatus(BaseThingHandler.java:372) ~[?:?]
at org.openhab.binding.gardena.internal.handler.GardenaThingHandler.updateStatus(GardenaThingHandler.java:317) ~[?:?]
at org.openhab.binding.gardena.internal.handler.GardenaAccountHandler.onDeviceUpdated(GardenaAccountHandler.java:153) ~[?:?]
at org.openhab.binding.gardena.internal.GardenaSmartImpl$RefreshDevicesThread.run(GardenaSmartImpl.java:560) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
During the starting a quite similar error is occuring:
2020-03-22 20:19:28.594 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method âThingHandler.initialize()â on âorg.openhab.binding.gardena.internal.handler.GardenaThingHandler@1bb6e01â: Illegal status INITIALIZING. Bindings only may set UNKNOWN, ONLINE, OFFLINE or REMOVED.
java.lang.IllegalArgumentException: Illegal status INITIALIZING. Bindings only may set UNKNOWN, ONLINE, OFFLINE or REMOVED.
at org.openhab.binding.gardena.internal.handler.GardenaThingHandler.initialize(GardenaThingHandler.java:73) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
Interesting point is that in the Gardena app I instantly get an error âIm Masterkanal liegt ein Fehler vor, bitte checke den Masterkanal fĂŒr weitere Detailsâ (Roughly translated: Error in the masterchannel , please check the masterchannel for more details). The only option I get is to reset the error and after that the app is working properly again. The error is only coming again when I try to control the valve via openhab.
Any ideas what I can do to solve this? Or could that be an issue in the actual binding with changed interfaces due to a gardena firmware update and I am quite early to test the new years version? Is there anyone already running the irrigation control with the actual firmware/openhab-version?
